Scratch Build – In Progress Matrix Table Desk PC
Discussion in 'Project Logs' started by Matrix74, 19 Aug 2015.
  1. Matrix74
    Matrix74 What's a Dremel?
    16 Aug 2015
    :naughty::naughty::naughty::naughty::naughty:
    Tomorrow is another day..............
    :idea::idea::idea::idea:
    :read::read::read::read:
  2. Matrix74
    16 Aug 2015
  3. stealth80
    stealth80 Minimodder
    1 Feb 2015
    I was really expecting a green and black theme, I wanted to do something similar a few years ago with a side window etched with the above pattern with UV Green lighting, never got around to it.
    Looking forward to see how this turns out!
  4. Matrix74
    16 Aug 2015
    It would have been too heavy sincerely ..... ..... black and green, although I never thought ....
    I found, however, the precautions that they gave me an Idea ..... fantastic!
  5. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Well the only thing I see missing here is Carrie Ann-Moss otherwise awesome work so far.
  6. Matrix74
    16 Aug 2015
    If I put a woman, I put my wife ... which is better ..... Several:thumb::thumb::thumb::naughty::naughty::naughty::naughty:
  7. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    As ı saw your desk, said that this desk is correct is desk .
    Becouse we see this error in most desks
    we do not sit on the back side of the table
    Keyboard ,Mousepad and Mouse.., they should not be here.
    If we get them to the right place…
    not much thing left…from the Show case…
    but you've fallen into the same error with adding of two ext. reservoirs .
    you have the same error.
    No more place for Keyboard and for mousepad.
  8. itrush07
    itrush07 Minimodder
    28 Nov 2007
    Wow, can't wait to see the finish part.. keep us posted..
  9. Matrix74
    16 Aug 2015
    You are definitely right. In the initial design I forgot to create the sliding top that will host keyboard and mouse that you hide under the desk. In the central area you've noticed to be there ... the tanks! Scomèparsa will be under the desk and will have a front door to keep her from seeing when the PC is off ....
    Here...........!:thumb::D
  10. Matrix74
    16 Aug 2015
    This beautiful radiator has a problem. at least what I have. The housing for the fan is composed of a slot where as inserting a small nut. So, on the one hand there were these little nuts on the fly and ran to touch the other instead we were forced ....
    For which in the assembly phase it would have been a dramatic thing to be able to mount nuts 12 and they were standing still. For which I use this little trick .....
  11. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    No matter when you see and fix the problem.
    Achievements.:thumb:
  12. Matrix74
    16 Aug 2015
  13. arg-ist
    arg-ist Minimodder
    21 Dec 2013
  14. Matrix74
    16 Aug 2015
    Here you pass the test of assembly fittings and pipes with flow meter and what will be visible in that part of the desk.
    Mounting the waterblock on the GTX980..............
  15. Matrix74
    16 Aug 2015
    One more approach of mounting all fittings, this time with the GTX mounted on Motherboard ...... and then in final position.
  16. Matrix74
    16 Aug 2015
    And some evidence of positioning strip LED on the motherboard, but I was not very convinced. I have to do some checks on where to get better..
  17. Matrix74
    16 Aug 2015
    This is the detail of the shelf under the motherboard that is completed with the white plastic frame, and will be illuminated.
  18. Short Modder
    Short Modder What's a Dremel?
    2 Jun 2015
    Coming along pretty well!
  19. Matrix74
    16 Aug 2015
    Small update.
    the pictures that I have entered riposrtato small differences. The side walls of the cabinet have temporarily this logo, but will be incorporated logos or images with the LED backlight.
    Good vision.
  20. Matrix74
    16 Aug 2015
    Here we modding the cover of the Asus Sabertooth Z77 that will act as a second PC .....
    I leave the pictures ..... I hope you enjoy it. ........... I forgot, did not stop there modding ........ :p
