Memory Max Memory Confusion
Discussion in 'Hardware' started by Yeoo, 26 Jan 2012.
  1. Yeoo
    Yeoo Minimodder
    1 Sep 2011
    Hi guys i need some help i have a ASUS M4-N68t v2 le It says i can have... 2 x DIMM, Max. 8GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory
    Is that max of 8GB or max 8GB per DIMM
  2. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
  3. Malvolio
    Malvolio .
    14 Dec 2003
    Wait just a tick here: where did you get that information from, Yeoo? On Asus' own site - as linked to above - they say the board can support 16GB max, so I'll hazard a guess that what you've read is either inaccurate, or outdated (you may need to update your BIOS to allow for full memory utilization).
    Unless you've typed in the incorrect model number in your original post :D
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    8GB will be the real world max, since it's basically impossible to find module with 8GB density, so a 2x4GB kit...
    Just like I have a board that 'support' 32GB, but 2 dimm slots... yeah right.
  5. Malvolio
    Malvolio .
    14 Dec 2003
    But the board has four DIMM slots...?
  6. faugusztin
    11 Aug 2008
    8GB memory modules are pretty common these days. :eyebrow:
  7. IvanIvanovich
    31 Aug 2008
    I shouldn't be posting on forums so early... didn't see v2... other one only have 2 slot. Also it's been a little while since I looked, and apparently 8GB modules are easily available now, which weren't not too long ago. I'm not perfect.
  8. Yeoo
    Yeoo Minimodder
    1 Sep 2011
  9. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    I've done some googling and you can install 16gb on this board. 2x8gb. HTH.
  10. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
  11. Yeoo
    Yeoo Minimodder
    1 Sep 2011
    Thank you guys
