Storage Maxtor hard disc issues
Discussion in 'Tech Support' started by jazzzyj, 28 Sep 2013.
  1. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    So I have a pair of maxtor 150Gb discs which seem to be playing up. They hold data ok, but randomly when accessing them they go to 100% active but data transfer is 0%.
    This then locks up explorer and the only way to get back to normal is to reboot.
    I've scanned them with hard drive pro and they seem ok..
    What can I do with them? Are they fixable? Should I just cut my losses and get something newer and bigger?
    These are about 9 years old now!
    -J
  2. droyden
    droyden What's a Dremel?
    6 Sep 2011
    You say pair, are they running in a raid set? Is the rest of the hw as old as the HDD? Personally I would be inclined to replace asap.
  3. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    No they weren't set up in a raid, but they have followed me over 3-4 different motherboards.
    -J
  4. droyden
    6 Sep 2011
    Have you run hdtune on them? Likely they are sata1..
  5. jazzzyj
    jazzzyj Minimodder
    2 Apr 2002
    I think they must be sata 1 they sure are old enough!
    What do I need to run in hdtune? What am I looking for?
    -J
  6. droyden
    6 Sep 2011
    Health tab with smart data, green is good. Run an error scan too
