Mayhems Aurora???
Discussion in 'Watercooling' started by quizz_kid, 1 Sep 2013.
  1. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Hi guys.
    I would like to give Aurora a try, but first some questions:
    * This is my setup:
    CPU: Alphacool NexXxoS XP³ Light - Acetal Edition
    GPU: Alphacool NexXxoS NVXP Nvidia GTX680
    Pump: Alphacool DC-LT Ceramic - 12V DC Pro with plexi top
    Radiator: Alphacool NexXxoS ST30 Full Copper 360mm
    Res: Alphacool Cape Corp Coolplex Pro 10 - Copper Edition
    10/16mm clear tubing
    ... a pretty basic setup I guess. Is it ok for Aurora?
    * I know it's more of a show-off coolant, but some people must be using it in their home setups. I would be nice to hear some overall real-life experiences?
    * I would like a black coolant. There are no ready-made Auroras in black, but I've seen videos of people dye mixing with Aurora Supernova. Do you use some special kind of dye when mixing with Aurora?
    * Let's say I'm using Aurora and I want to replace it with a regular clear coolant, are the "peals" hard to get rid of?
    //Quizz
  2. faugusztin
    11 Aug 2008
  3. Pierre3400
    Pierre3400 What's a Dremel?
    22 Aug 2013
    Back when i was planning my loop for my main rig, I wanted to use see threw tubing and white water.
    I was told, that unless I wanted to drain and refill all the time, the best would be to buy white tubes, and run distilled water with additives.
    Aurora was also on my wish list at one point, but as mentioned, it really is only a show off liquid, not an everyday liquid.
  4. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    It's a show coolant that needs replacing after 3 months which is why the utopia PC reviewed recently is so awful. Rma 6+ times during the warranty period. Needs solid fluid to be viable.
    I used it, never will I use it again.
  5. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Thanks for the quick answers guys. No Aurora then, guess I'm going for pastel black then!
  6. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    im on the pastels and its working perfectly :)
  7. Big Elf
    23 Apr 2009
    Pictures please.
