Peripherals Mechanical Keyboards
Discussion in 'Hardware' started by Raptor77, 27 Dec 2011.
  1. Raptor77
    Raptor77 What's a Dremel?
    15 Dec 2009
    I've always had a keyboard with a stepped key and I was used to having it there. I kind of rest my little finger half on the "a" key and half in the gap from the caps lock step. I do use the home key bumps as well but it helps me type. There was someone on geekhack or similar describing the same thing but I can't find it at the moment, he said he types like that because he got used to using the step to find WASD for gaming, which might well be why I do it as well.
  2. longweight
    7 May 2011
    Fair enough! I have found that ISO keyboards annoy the hell out of me now. I have been using ANSI mac laptops for about 4 years now and I now have an ANSI mechanical keyboard at work and home. The large enter key really annoys me!
  3. Raptor77
    15 Dec 2009
    What annoys you? The look? I think I probably need the large enter key; I tend to press either the centre or the top edge of the ISO enter key. Having "\" and "/" on opposite ends of the same row is much more intuitive for me as well.
    I'm sure I'd put up with ANSI if I found something cheap ha.
  4. longweight
    7 May 2011
    No I repeatedly miss hit keys on ISO layouts now and ANSI does look much cleaner!
  5. GeorgeStorm
    16 Dec 2008
    While I don't like the idea of ANSI (it being American) I've found myself using it completely now since you can't really get replacement keycaps for ISO :(
    Also some boards (such as the poker) only come in ANSI, so I have no choice. I still use UK layout in windows though, which actually means I have no backslash :/
  6. longweight
    7 May 2011
    You need to learn the ASCII for certain things :p
  7. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    SP Red ESC on my Poker, enjoy:
    Brendan
  8. GeorgeStorm
    16 Dec 2008
    Looks awesome, my portal keycaps still haven't arrived :(
  9. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    yup very nice keyboard, i always liked the look of poker.
  10. McDuff32
    McDuff32 Minimodder
    5 Aug 2011
    Nuforce Icon UDAC-2? Is it worth the money?
  11. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    Naw the 1, was going to get the upgrade kit. I mean, it's $129 for hi res capabilities, I personally enjoyed the sound, I think it's a great value. Though I primarily use it as an actual DAC not a headphone amp.
  12. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
  13. cyberspyder
    cyberspyder Canuck
    26 Nov 2006
    You should be looking at Cherry boards with the H prefix...doubleshot caps are worth getting.
  14. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Well, yes the doubleshots are nice, but Cherry makes some damn nice pbt, which most older white/beige are, and pom which most older black are keycaps. The new ones are mostly abs and almost all the bigger than single keys are no longer fully MX compatible on G81/MY. You need to be careful with those if getting them for caps. No sane person is getting them for the boards, as MY switches are fairly terrible feeling. Technically they are still mechanical I suppose... but nasty.
  15. shrop
    shrop El Jefe of Sleeving
    22 Jul 2011
    I've got my finger hovering over the buy now button on a Filco Majestouch Tenkeyless with brown switches, I just can't make my mind up whether or not to go for it, or just cheap out and go for a Tt Meka or a SteelSeries 6GV2... ARGHHHHH!!!!! £120 is mental for a keyboard, make me buy it BitTech!! :worried::lol:
  16. el2k
    el2k Modder
    18 Jan 2010
    I'm literally in the exact same boat.
    Like how much better is the Filco over the cheapy gamerish TT Meka etc.
  17. longweight
    7 May 2011
    Just man up and buy the Filco. Ninja. ANSI.
  18. IvanIvanovich
    31 Aug 2008
    Thermaltake Meka G1 Same as Mionix, WASD, some others... good quality, made by costar just like the Filco. But, you have only choice of mx black switch. the other Thermaltakes are I think made elsewhere, and have terrible non standard layout. Forget replace keycaps easy.
    Filco do look nicer sleeker, use standard layout, and have choice in switch.
  19. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    some people like ISO!
  20. longweight
    7 May 2011
    Some people are perfectly within their rights to be incorrect and choose ISO :)
