Build Advice Media OSX Computer
Discussion in 'Hardware' started by Kaiwan, 1 Feb 2011.
  1. Kaiwan
    Kaiwan Shinigami
    29 Dec 2010
    Media OSX Computer
    So I'm helping my friend build a media computer that he wants to dual boot with Win7 and OSX. Now I can suggest gaming builds till the cows come home but this is out of my comfort zone. He's in Canada so I'm not sure if that will influence any components.
    Now there really isn't any set budget just that he doesn't want to upgrade for quite a while. For arguments sake let's say C$1600.
    Overclocking is a possibility and a sufficient hard drive for storage. I was thinking an F3 1Tb.
    The main aims are CAD, HD films and to run silently. This is just the base unit. No screen or peripherals.
    Any suggestions guys?
  2. r3loaded
    r3loaded Minimodder
    25 Jul 2010
  3. adam_bagpuss
    24 Apr 2009
    dont bother with OSX its not worth the hassle getting it to run on custom hardware as even when its working its not 100% perfect.
    a media PC should be as hassle free as possible with minimum input needed from the end user.
    id go with just a mac mini or a PC
    although not sure on CAD requiremetns and a PC would get better performance for your cash.
  4. Kaiwan
    Kaiwan Shinigami
    29 Dec 2010
    That's ridiculously expensive.
    He basically wants mac for just about everything. Except most cad applications don't run on OSX.
  5. adam_bagpuss
    24 Apr 2009
    well since you can do everything else on windows 7 why not just stick with that ?
  6. saspro
    saspro IT monkey
    23 Apr 2009
    If you want a mac then buy a mac.
    You can always vmware fusion windows 7 from inside the mac operating system for the CAD programs
  7. jrs77
    jrs77 Modder
    17 Feb 2006
    What kind of CAD are we talking about? Professional use or just playing around a bit?
    If it's just for some AutoCAD to play around with and draw some easy stuff, then a macMini with 4GB RAM will handle it allready and AutoCAD is available for MacOS aswell, making Win7 moot.
    Need more details there actually about the CAD-part.
  8. Kaiwan
    Kaiwan Shinigami
    29 Dec 2010
    We're talking full car models. From the nuts and bolts to the bodywork. No fea is going to be run it's basically for packaging and geometry.
  9. adam_bagpuss
    24 Apr 2009
    id opt windows 7 just because you will have a lot more RAW power for the same price as a mac
    which will help considerably with CAD app using geometry
    you got any tesselation and high point counts too ?
  10. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Unless he's going with any Mac specific programs, there is no point in going the Mac OS X route. At all. It's simply too expensive for him by the sound of things.
  11. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    why does he want to run his CAD software on his media PC?
  12. jrs77
    jrs77 Modder
    17 Feb 2006
    OK, with that information given... forget about MacOS and buy a decent rig (i7-9xx + 12GB RAM + GPU with lot's of RAM) and go with Windows 7 64-bit.
    For HTPC build something cheap based on an IONITX-board additionally and run Ubuntu+XBMC on it.
  13. Kaiwan
    Kaiwan Shinigami
    29 Dec 2010
    I've tried telling him all this but he insists that he loves his mac book so he wants to run OSX on this media/workstation. Certainly likes a challenge. -.-
  14. jrs77
    jrs77 Modder
    17 Feb 2006
    He can't run MacOS on a self-made rig decently and without some hacks.
    If he want to run MacOS X then he needs to buy a Mac, and with this CAD-thingy, he would need to buy a MacPro at two-three times the cost of a Windows-machine.
    There's no other solution to this.
    If he still insists on running MacOS on a WinPC, then show him this -> http://wiki.osx86project.org/wiki/index.php/Main_Page and let him decide if he want to go down that route with all the possible problems included ofc.
  15. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    I have a friend that wanted pretty much the same thing, i tried for ages to convince him just to get a high spec PC running win7 OR a mac.
    He wouldnt have any of it. In the end i told him to sort himself out because he wasnt listening to sound advice, and i couldnt be arsed.
    So now he has a mac that cost more than the PC would have and he doesnt like it! Im sure he'll listen next time though.
  16. murraynt
    murraynt Modder
    6 Jun 2009
    Use the laptop for most tasks and a really fast PC for CAD?
    maybe Linux if he want's to be different.
    If he won't stretch anymore that is the only real solution.
    mac lovers and haters will tell you that.
  17. Kaiwan
    Kaiwan Shinigami
    29 Dec 2010
    *sigh*
    It is exactly as I feared. I'll get him to make a PC. Eff that apple bollox.
