Modding Memorex keyboard mod - my first
Discussion in 'Modding' started by Grump, 3 Apr 2002.
  1. Grump
    Grump The Mad Modder
    30 Mar 2002
    Yep, Spring has sprung.
    I wonder how many people realize that dreary days produce dreary paint jobs? Don't paint when the humidity is too high or it's raining -- unless you're enclosed in a warm, dry area (don't fergit circulation though).
    Grump
  2. Grump
    30 Mar 2002
    Well, another dreary weekend. I did manage to get a coat of clear on the board though. I also got some chrome look goin' on with the keys -- I only plan to do the Shift, Enter and Spacebar keys. I'm not done, but here's what is so far:
    Clockwise from the top: Monitor control panel, Enter, Shift and Spacebar, monitor power button, case power button, and the release buttons for the upper bezel of the case.
    It's turning out pretty nice. Wish I had more to show.
  3. GunDam
    GunDam Minimodder
    9 Feb 2002
    Wow ! Thats looking well Schweeeet! Grump could u post some close ups of those chromed items...I'd like to see the quality :dude:
  4. Grump
    30 Mar 2002
    GunDam, I didn't mean to ignore you. I'm sorry I didn't post another pic of the chrome for ya.
    Howzat? The chrome tape (Flexi-Chrome) turned out good, but I found out the buttons wouldn't fit in their tight little holes. So, I had to take off the tape and paint the buttons with "chrome spray paint". It ain't **** compared to the tape or even the real thing (the metal parts here are nickel plated), but they'll have to do if I wanna turn this machine on an' off.
    I wish I could add more on the keyboard, but the weather has been very crappy these past few weeks, so I can't get any clear coats on. After that, I'll be doing some lighting effects.
  5. Grump
    30 Mar 2002
    Well, I finally caught a break and we're havin' some good weather. I had to repaint ever'thing because I painted in the wind and screwed my paint job up. I broke down an' bought a spray gun and a carport tent and I like the results much better. The pics below are after 3 coats of primer, 4 coats of metallic green and 4 coats of clear. I don't know how many hours I have in sanding alone, but at least I didn't have to sand between the color coats (you can't sand metallics unless you wanna start over).
    As you can see, there are a few "chromed" keys -- the Flexi-Chrome that I got from TapeWorks turned out real nice. It's the next best thing to having the plastic parts chrome plated, but I don't know where to get that done (regular platers don't usually do plastic).
    I put the thing back together last night, but a lot of the keys stuck. I guess it was too many coats of paint. I took it apart, filed each hole and lubed the keys with Labelle 106, a plastic compatible lubricating grease with PTFE that I picked up at a hobby store. After getting it back together, I feel a little difference in the touch, but it works fine.
    I haven't done any lights yet. That will have to wait. I also did not change the LEDs to blue -- this is a metallic green machine and the green LEDs look great with it.
    The trackball is done too. It's hard to rell with these damn pics, but the trackball is a shade lighter than the keyboard and, in 3D, the two look sweet together. The buttons are "chromed on it too. I did have to leave the ball blue though.
    The rest of the machine is coming along fine.
    I'll post more pics when it's done.
  6. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Nice work m8 ... is that a stone effect on the mobo tray?
  7. Grump
    30 Mar 2002
    Sorry, SpiKe, that's a pretty blurry picture. It's called Trunk Paint. It's a gray/white/black splatter type of paint and it has a heavy texture. It actually looks good in 3D.
    Grump
  8. GunDam
    GunDam Minimodder
    9 Feb 2002
    Wow Grump that project is looking ever so sweeeeeeeeeet.
    Can't wait to see it once its finished !!!!! Keep up the excellent work m8 !
  9. Jamie
    12 Mar 2001
    I was looking at that paint a while back and was wondering how a case would look with a stone theme :D
    Looking forward to more pics ;)
  10. Lazy
    Lazy Meow?
    13 Nov 2001
    will be getting me some of that chrome paint :D
    one thing you could do is do a neon string keyboard as they look really cool. Mine only took me 30 mins to do.
  11. tk421
    tk421 Idiot.
    15 Jan 2002
    wow. i want my monitor to look like a bass boat too!!!! that paint job is really nice, grump.
  12. Ace_03
    Ace_03 What's a Dremel?
    23 Apr 2002
    that is sooo sweet dude, what would be neat... do the inside of a case like that, or... how about everything!!!!!!!!
