Build Advice Memory and cpu fan advice (3600 build)
Discussion in 'Hardware' started by Boswell, 10 Apr 2020.
  1. Boswell
    Boswell Minimodder
    23 May 2005
    Hello everyone,
    I’ve just purchased a 3600 and the ASRock X570 steel legend board. I need to buy some memory but struggling to understand what definitely adds value for the money.
    • I’m not going to overclock it
    • Computer is for photo editing (photoshop and Lightroom) and some gaming
    I’m thinking 32gb for the photo editing, but I don’t understand the memory MHz - it seems like the consensus is anything over 3000 MHz is fine. Is this true? Are the gains over 2400 MHz worth the extra money?
    My budget is around £150 - I’d prefer to spend less if I can get away with it. I could also spend more if the performance gains were that good.
    thank you!
    edit: totally forgot to ask about CPU fan.
    budget is £50-60.
    Is it worth keeping with stock cooler or upgrading to something?
    I’d ideally like to keep things fairly quiet.
    Not bothered about aesthetics.
  2. Vault-Tec
    30 Aug 2015
    Boswell likes this.
  3. Boswell
    Boswell Minimodder
    23 May 2005
    Great thank you I’ll buy the second one in that case.
    I’ve made an edit to my original post to ask about the cpu fan!!
