I have had enough of having different mobile memory sticks. Since there are converters to put the memory stick micro into memory stick duo pro/sd the pin layout can not be different. Once i take the blue cover off the memory stick duo pro i can fit the memory under my phones battery very easily and could put thin cables from under the battery to the micro memory slot. Do you think that it is possible to use the memory in this way?
