Storage Memory stick to external hard drive
Discussion in 'Hardware' started by jopers1986, 26 Nov 2012.
  1. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    Hi All,
    Does anyone know of a company that does a function to copy straight from a memory card/stick to an external USB hard drive?
    I have a NAS drive which has a copy/sync function where you can plug in a stick and it copies everything across, but can't find a USB drive to do it...
    Any help would be appreciated!
    Rich
  2. Parge
    16 Jul 2010
    Any memory stick with enough capacity will do it won't it?
  3. ferret141
    ferret141 Minimodder
    18 Oct 2010
    I think he want's a device with the automatic backup function built in.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    Is it a USB memory stick or a memory card (SD/CF/XD etc) that you want to copy from?
    I've seen devices to copy memory cards but they weren't cheap...
  5. jopers1986
    7 Jan 2005
    yeah will be memory cards, but could use a converter if the device takes USB? but yeah, auto back up without a PC really is what i'm after. Thought they'd be a cheap option out there somewhere, my NAS was cheapo fantasico and has it built in...!
  6. Atomic
    Atomic Gerwaff
    6 May 2002
  7. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    You could build some thing that does this with a Raspberry Pi or similar.
    The trick to doing this is you can't really use any thing less than a full operating system to do this as it needs drivers for all the things you could plug into it. So prior to devices like the Raspberry Pi you would end up spending quite allot on hardware for not much functionality.
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    A Pi and an SSD would be a killer combo, super small and not prone to shock damage like a traditional HDD.
