Good evening sports fans. I want to add a side-fan to my Fractal R4. I already have the fan (120mm) and the case has a mount for a fan...but it doesn't have any mesh or filter to keep the dust out. Will this stuff do the trick or is there anything else I should consider? https://www.amazon.co.uk/dp/B01303J...UTF8&colid=3S231N5Y4SOQF&coliid=IZTEITAPPVFY9 Cheers
Demciflex are well regarded for making nice fan filters with convenient magnetic mounts (i.e. you just flap them onto the side panel). Only downside is he is based in SA, so SA postal strikes can affect delivery times. A more limited selection of Demciflex filters are on Amazon, so if the one you need happens to be there that would be faster.
Have a look on Scan https://www.scan.co.uk/shop/computer-hardware/all/coolers-air/system-case-fan-accs I use the Silverstone 120mm & 140mm with Magnet
Tights, duct tape and super-glue sounds kinky. What techhead said, the Sivlerstone magnetic mounting filters are quite good. I have used lots of them. For 120mm fans the SST-FF122B us lowest priced https://www.scan.co.uk/products/120mm-silverstone-sst-ff122b-with-cleanable-fan-filter-with-magnet But SST-FF123B look nicer https://www.scan.co.uk/products/120mm-silverstone-ff123b-fan-filter-with-magnet-120mm-vents-or-fans
