Disaster Messin with molexes
Discussion in 'Modding' started by Stwongbad, 30 Jun 2006.
  1. Stwongbad
    Stwongbad What's a Dremel?
    8 Jun 2006
    Not really a mod but still a diaster but the story is
    Im on my computer when my blue side panel fan begins to flicker so i undo the side panel and look at the molex and see that its conected fine but one of the pins is falling out so...me being the tired dumb-butt i just...push it back in? and button it up. so a couple minutes later it starts again and i open it up in that pissed sleepy mood and rip out the molex......bad move :wallbash: :duh:
    Entire computer pzowns itself try unplugging everything/plugging it back and after a minute of staring at the computer thinking "I am sooo skrewed" I hear what sounds like a discharge so i plug in the computer and everything is fine....except a couple years of my life scared out of me
  2. Springs
    Springs Boing boing
    29 Aug 2004
    ive done that before... shorted it out... computer turned off and it wouldnt turn back on... i was crapping myself thinking i have just blown a few hundred quid computer up.. but luckly it turned back on a few mins later...
  3. Stwongbad
    8 Jun 2006
    yep! exact same thing i swear i dont know what i would have done if it never turned back on...
  4. Al Terego
    Al Terego What's a Dremel?
    5 Jun 2006
    I also did that..gawd..I swear my heart stopped for a few seconds.
  5. dragon2309
    dragon2309 techie
    28 Jul 2006
    lol, yeh, its ok when it swtiches off, you kninda think "i was expecting that" its just when you ht the power button and nothing happens, or you hit the button and the fans spin for like half a second. Thats when your heart skips a beat. Not so much on older systems, but when youve just spent £1500 on a brand new box, you really do need to visit the toilet afterwards...
    dragon2309
  6. kbates666
    kbates666 What's a Dremel?
    24 Jan 2006
    Also had this happen to me, a loose molex grounded against the case and sparked. I was thinking bad, bad, bad, bad, bad but luckaly the computer turn on after a couple tries.
  7. John_Edward
    John_Edward What's a Dremel?
    21 Dec 2005
    Same has happened to me many times too.
    You just need to shut your PSU for a few minutes and try again after that.
    Usually its enough if the LED(s) in the motherboard shut down.
  8. Stwongbad
    8 Jun 2006
    well....not everyone has LEDs in their motherboard.....
  9. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    The pop sound is the self reseting circuit breaker. When I first had my computer my cousin shortened every fan wire or lenghtened it he shorted one. The thing kept shutting down. I found the short fixed it.
  10. dragon2309
    dragon2309 techie
    28 Jul 2006
    Talking about shorting wires now, it was only 5v (inside the network switch ive been talking about in the electronics forum), the fan died in it so i had it all open, found a normal 12v fan and hooked it up, because it was a cut & shut job with the wires some bare metal was still showing, as i put the fan down the wires relaxed and fell onto the casing of the switch, not a good thing, a few sparks, it shut off and the + and - wires fused together lol, fan and switch still work perfectly though
    Another thing happened in that switch aswell, when i was fiddling about my little finger accidentally touched the big yellow block in the PSU, all i can say is i thik that yellow block is BEFORE the step down to 5v, lol, arm was pounding for about 30mins, then it ached like hell for about a week, lol. havent touched that part since, lol....
    dragon2309
