Windows Metal Gear Solid 2 Help!!
Discussion in 'Gaming' started by Jammy_eel, 18 Jul 2008.
  1. Jammy_eel
    Jammy_eel What's a Dremel?
    2 Mar 2008
    Hello,
    With the release of MGS4 i decided to get through MGS1 and MGS2 to get the grip of the storyline. The thing is MGS1 worked perfectly on my pc and i succesfully beat it. However, when i installed MGS2 and try to run it, im given a black screen with no sound!! :waah:
    Ive googled it and i am not the only one having this problem, i tried the v2.0 patch which i think is suppose to solve it but still no success.
    Pleaseeeee help me solve this as i really want to beat MGS2 substance so i can play mgs4 knowing the story. :D
    Thanks.
    PS: i do not have a ps2 so cant really play sons of liberty instead or play snake eater..
    EDIT: im running Windows Vista and have a ATI X1300 graphics card and no sound card.
  2. Jammy_eel
    2 Mar 2008
    I have moved this to the tech support forum, sorry i think thats where its suppose to go :sigh:
  3. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    Never tried it on PC, so I suppose I can't help you... what sort of rig are you running?
    I saw it for PS2 for £4 at GAME the other day, so maybe you should try that instead...
  4. superpooper
    superpooper What's a Dremel?
    8 Jun 2008
    sounds like a vista incompatibility to me :(
    I dualboot vista and xp. For really old games I run dosbox.
  5. Snaek
    Snaek What's a Dremel?
    10 Jan 2004
    I know you said you don't have a PS2, but Substance is also on the original XBox if you have one or a 360. Sorry I think of anything to get it to work on the PC.
  6. Solidus
    Solidus Superhuman
    26 Dec 2005
    I dont think mgs2 works in vista, I tried it before on my vista rig and it didnt work - I think its only configured for XP.
    I would try it on an XP computer first and see if that helps!
  7. rjkoneill
    rjkoneill What's a Dremel?
    11 Feb 2008
    it doesnt work in vsta
    try an xp machine if you can
  8. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Stupid question alert (Not intended to insult anyone): Have you tried to run it in compatibility mode?
  9. rjkoneill
    11 Feb 2008
    i ran it on vista 64 and compatibility mode didnt do anything
    32bit may be different
