Scratch Build – In Progress Metaversa 02: Ada
Discussion in 'Project Logs' started by Nexxo, 21 Jan 2014.
  1. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    I know that,im an old boy now.......so is triclorethelyne....dosent stop me having 25ltrs sitting in my shed.
  2. mikediflip
    mikediflip What's a Dremel?
    2 Nov 2015
    Wow the attention to detail and precision is mind blowing. Could you imagine if off the shelf cases were made to this standard? Amazing work!
  3. Cheapskate
    13 May 2007
    Yay! Let's have a party. I'll bring some DDT and asbestos drywall.
  4. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I've got xylene, lots of pure lead, all kinds of nasty, nasty paints, all kinds of that good stuff. Let's all get cancer!
  5. uerseya
    uerseya Covered in rock wool
    25 Aug 2008
    Can I add my mother-in-law to that lethal cocktail ? 5 seconds around her is enough to fray your sanity, she's pretty good at stripping paint just by being in it's mere presence :nono:
    EDIT: On topic, great build, tho' I've seen glaciers move faster :clap:
  6. Cheapskate
    13 May 2007
    Back off topic: Can I borrow your mother-in-law? I have a tenant that painted the kitchen like the red room from the amityville horror.
  7. uerseya
    25 Aug 2008
    Sure ... you pay shipping from the UK, she's Chinese so shouldn't cost too much :idea:
  8. Supercluster
    Supercluster I dream in G-code
    16 Feb 2015
    I apologize if it's against the rules, but I want to share (for potential ideas and whatnot) this youtube channel because of the amazing engineering and machining this man is doing, particularly with brass, as I find it related to the build.
    Cheers
  9. Nexxo
    23 Oct 2001
    No worries, that is a useful link. :thumb: It's everyone else who is poisoning this thread... literally. :p
  10. Cheapskate
    13 May 2007
    Very Useful link, but you may have just put the next update back a month.:worried:
    @uerseya - Pass. The Chinese here won't go near the neighborhood. :lol:
  11. uerseya
    25 Aug 2008
    But she's a right (amityville) horror :eeek::eeek::eeek:
    Anyways on topic ....
  12. Teelzebub
    27 Nov 2009
    Nexxo where are you
  13. Nexxo
    23 Oct 2001
    Nexxo is very, very busy... But the build progresses apace. This week I have been mostly concentrating on the PSU cradle. This is slow work as there are a lot of pieces to it that need many operations performed on them, with high precision... The idea is that the cradle clamps the PSU firmly and then slides into the case. Which means that a lot of pieces have to line up exactly.
    The materials used:
    10mm x 15mm aluminium bar, 10mm diameter brass bar and 6mm brass bar.
    There was a lot of old skool sawing...
    And a lot of milling:
    The result of a day's work:
    Next: drilling out and countersinking for M4 screws:
    Subsequently there was some test fitting and some filing --because even 0.1mm deviation can cause problems (the small gaps will disappear when the cradle is screwed in place). For kicks I also plugged in the power cord which I made some time ago:
    Here an overall shot to give an impression of how the case is coming along:
    Of course, there is a lot more work to do on the cradle --I have not got to the brass bar yet! And the PSU will itself be subject to slight enhancement.
  14. Teelzebub
    27 Nov 2009
    Nice to see you're still creating a piece of art
  15. Parge
    16 Jul 2010
    Sometimes I wish swearing was acceptable on bit tech. This is one of those times! Holy...
  16. Nexxo
    23 Oct 2001
    More stuff coming up soon. There's just been a lot of fiddly parts to make. Below for instance are 8 bevelled 10mm washers, 2.5mm thick with a 1mm depth recess of 6mm diameter and a 4mm hole...
  17. Cheapskate
    13 May 2007
    You're giving poor Nexxo mixed signals here. Maybe you should say, "Work at your own pace, but update religiously."
    You have to move at a fairly steady pace, or your tastes will change as you work. Then you get sucked into revision hell.
    Looking lovely. I would have left a gap and mashed some glue or foam in there instead. You don't seem like the Velcro type, honestly.:p
    disturbed13 likes this.
  18. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    Looks great! Soooo much work going into this one
  19. Nexxo
    23 Oct 2001
    No revisions, don't worry. Although the design has grown more intricate along the way as I have acquired more tools and skills. :D I have been working out some interesting ideas that will be included in the build...
  20. Nexxo
    23 Oct 2001
    Current progress on the PSU cradle...
    Test assembly:
    Next up are the end pieces for the brass rods which will form the pull-out handles for the PSU cradle. The brass rods have an additional function; an adjustable cable organiser bridge will span the upper two.
