News Microsoft issues emergency Intel microcode-disabling patch
Discussion in 'Article Discussion' started by bit-tech, 29 Jan 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Vault-Tec
    30 Aug 2015
    Unpatch the patch ! :D
    Glad, though. My PC turned to poop last week.
  3. Guest-44432
    Guest-44432 Guest
    So should you just uninstall windows update KB4056892 & KB4058702?
  4. adidan
    25 Mar 2009
    Well I've had no random reboots so I presume leave as is?
    I'm losing track of it all what with all of Intel's half assed moronity.
    alfizzle likes this.
  5. yuusou
    yuusou Multimodder
    5 Nov 2006
    No weird issues here, but running windows update didn't produce anything either, and I'm on Haswell.
  6. Guest-44432
    Guest-44432 Guest
    I've had a couple of random reboots, where the PC just switches off like the plug had been pulled. It then tries to reboot, but hangs at the bios until you clear CMOS. (I was wondering whether my PSU was on it's way out... Though that is after the PC has been on all day and usually during gaming for a few hrs.)
    Anyway, I've uninstalled them and put windows update on pause whilst I do further testing.
  7. Gareth Halfacree
    4 Dec 2007
    No, that will leave you vulnerable to Spectre Variant 1. Leave the previous updates installed and install the new update, which only disables Spectre Variant 2 protection (and fixes the reboots.)
    Guest-44432 likes this.
  8. Isitari
    Isitari Minimodder
    6 May 2009
    Serious question:
    Do I install the motherboard update to reduce the meltdown / spectre issue or leave it as is?
    (Z170 armor + i6700K)
  9. adidan
    25 Mar 2009
  10. Gareth Halfacree
    4 Dec 2007
    Do not install the motherboard update yet; that includes the faulty microcode Intel has now abandoned.
    Isitari likes this.
  11. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Quite so. I have no idea what to install or from whom. Is there some sort of list we can refer to? "If you have x installed, you need patch y from vendor z"?
Tags: Add Tags
