News Microsoft's Mini Start Menu delayed for Windows Threshold
Discussion in 'Article Discussion' started by Gareth Halfacree, 3 Jun 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. GeorgeK
    18 Sep 2010
    I know this isn't everyone's view, but I much prefer Win 8 (well 8.1) with Start8 installed...
  3. Parge
    16 Jul 2010
    Yeah, I have start8 installed and find Win8 excellent. Its so fast at startup and the multi screen support is a big improvement from 7. Don't ever use the Metro UI though - that thing is useless in every sense of the word.
  4. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Makes me wonder why they don't do a similar thing as Apple, have a desktop OS and a separate mobile OS, some stuff can be the same or similar or shared between both, just not everything.
    I'm sure there are somethings that are better suited to being used on there intended device, or are not needed on the other device, such as the Start Menu
  5. phuzz
    phuzz This is a title
    28 May 2004
    I'm getting used to 8.1 now, it's basically made me realise quite how little I used the start menu before, and now I just hit start, type the first few letters, and hit enter. The full screen menu is distracting, but the functionality is basically the same.
    The multimonitor support in 8 basically covers what UltraMon does/did.
  6. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    I get on fine with 8.1. But for customers I alway's bung on classic shell. I think it's too late for MS to implement the Start button now with Windows 8. They may aswell use it as a key selling point for Windows 9! They can even do TV ad's with the rolling stones "Start Me Up" song like they did for Windows 95 lol
  7. loftie
    loftie Multimodder
    14 Feb 2009
    If you use keyboard shortcuts you can also Win+s and type.
  8. longweight
    7 May 2011
    Or just Win.
  9. woods
    woods What's a Dremel?
    27 Apr 2010
    I only ever use the start menu in Windows 7 to shut down my machine I use Objectdock & windows explorer for everything else in Windows 8.1 I just use windows explorer pinned to my taskbar.
  10. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    Echoing this; I have regularly used programs pinned to taskbar and everything else is Win + type. Start screen is populated with calendar, weather and stocks to use the livetiles as widgets (never open the actual programs!), then all my Steam games pinned with Steam Tile (or Steam launcher, I forget which) purely for aesthetics.
    With 8.1 I don't even use the Start screen to shut down or restart, that's right-click "new start button" and select shutdown...
    Generally speaking, I have no complaints about 8.1
  11. Jim
    Jim Ineptimodder
    2 Sep 2007
    Disagree with that. In Windows 7, if I want to format a drive, I type partition, and hit enter. In Windows 8, for some unknown reason, I type partition, and it stares blankly at me saying "There aren't any programs called 'Partition'". I then have to go and click the "Settings" button or whatever it's called to see the option I wanted in the first place.
    I cannot, for the life of me, see how that's an improvement.
  12. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Yes, they changed somethings to have unintuitive names... like 'create and format hard disk partitions' but if you start typing partition it does come up after the 6th letter. Or you could just right click start and choose disk management.
    I personally don't think they should even bother with the small start menu. It makes no real difference. People should just get used to the start screen. It's not as if you are multitasking when starting a program. Either way if it was full screen or a small menu it has focus until you finished. It makes no difference... but with the full screen you don't have nested mess of crap like the old way. If you take the time to organize it (and clean up some of the garbage installers still dump in there which they are not supposed to) the start screen is super nice.
  13. Krazeh
    Krazeh Minimodder
    12 Aug 2003
    Update to 8.1 and that won't be an issue anymore.
  14. Zider
    Zider What's a Dremel?
    17 Sep 2007
    I don't miss the start menu at all, I never even tried Start8 and similar programs after upgrading to win8. Doubt I'd be using a start menu even if there was one now.
  15. Corky42
    30 Oct 2012
    You wouldn't have a nested mess of crap if you organised the start menu like you have done with the start screen.
    There still is one. It's just Microsoft renamed it the Start Screen, gave it bigger icons that you can poke with a finger, added some flashy icons to the mix, and moved a load of other bits around.
    The start screen is nothing more than a full screen version of the start menu on steroids.
  16. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    If it's much the same thing, why are you getting so annoyed about it? :p
    Never mind. Horses for courses, and all that.
  17. Corky42
    30 Oct 2012
    I'm not annoyed about it :confused: Sorry if it came across like that.
    In essence the start screen is the same as the start menu IMHO, a place for launching applications, but with a load of extra bells and whistles.
  18. Nexxo
    23 Oct 2001
    My bad. I agree though: same thing, different spin. I quite like the way the Start Screen works but feel that neither it or the Start Menu are perfect. Then again, it's a deceptively hard thing to get right, as most seemingly simple ideas are.
  19. faugusztin
    11 Aug 2008
  20. theshadow2001
    3 May 2012
    I bought it because at the time classic she'll wasn't up to scratch. And it was 5 dollars which isn't a whole lot
