Storage Migrating/Mirroring OS and programs from one SSD to another
Discussion in 'Hardware' started by pac-man, 27 Apr 2012.
  1. pac-man
    pac-man What's a Dremel?
    5 Sep 2010
    Hi everyone,
    I'm looking to migrate/mirror my entire OS including all programs etc from a 60GB Vertex first gen to a 120GB Vertex 3. I wanted to know the best way to do this?
    If I have to purchase a software license then that's fine as I'd be willing to pay. Still, if anyone knows a free alternative then that would be even better! :) I noticed a free clone software called 'CloneZilla'. Anyone used this before?
    Replies are much appreciated. Thank you in advance!
    P
  2. Teelzebub
    27 Nov 2009
    Acronis true image one of the best bits of software for cloning there is I always use it myself.
    PingPong likes this.
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I've used Clonezilla with no problems. It's just like that TV-advertised varnish - "Does exactly what it says on the tin".
  4. Pookeyhead
    30 Jan 2004
    Clonezilla works well, but buying Acronis also gives you a superb back up solution as well as a means of just cloning your drive.
  5. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    This, +1 to Acronis
  6. phuzz
    phuzz This is a title
    28 May 2004
    I've used Clonezilla a bunch of times and it's worked perfectly for me.
    (except when I was trying to copy a Macbook drive, with a Bootcamp partition to a larger drive, and expand both partitions, but that's a pretty niche case)
  7. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    I believe that would be ronseal
    As for ghosting I've used clonezilla and acronis and they both work well.
    But you could always just backup your appdata folder and other stuff then reinstall, with appdata backed up whenever you reinstall a program all the settings should be there still
    Sent from my Transformer TF101 using Tapatalk 2
  8. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I am aware of who owns the catchphrase, I was merely trying NOT to namecheck them.
  9. Dreamslacker
    Dreamslacker Minimodder
    13 Sep 2006
    I highly recommend Acronis TrueImage. Even the home version is much better than the the Symantec offerings.
    Clonezilla works well if you take note of the limitations for NTFS drives in particular. It cannot resize the partitions so your destination drive needs to be larger or equal in capacity.
    OTOH, Acronis can transparently resize the partitions to fit so long as your destination drive is large enough to hold the amount of used data on the source drive.
