Modding Mini GPU mod
Discussion in 'Modding' started by Goatee, 2 May 2019.
  1. Goatee
    Goatee Multimodder
    19 Apr 2015
    I saw a really interesting post over on SFF and it game me some inspiration for a build that's been hanging around for a while. I dropped this on as a reply but thought I would post here if anyone was interested.
    The base I used:
    NF-A92X14 @1400 RPM
    plus a 12mm thick heatsinkoff ebay
    With a bit of trimming and a couple added holes, this gives a 1.5 slot (~30mm) thick, extra short card (15cm) that's almost silent. At the moment I am getting 65c stable after an hour of Furmark, 25c while browsing. Ambient is 20c.
    Yaka, adidan and MLyons like this.
  2. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Very nice. What overall build is this going in? I guess it boosted higher as well.
    Goatee likes this.
  3. Goatee
    Goatee Multimodder
    19 Apr 2015
  4. kim
    kim hardware addict
    10 Jan 2016
    very interesting idea :thumb:...I'm actually looking for a low profile air-cooling rad/fan for a little build and prices are just insane:wallbash:...if that works for your GPU it could certainly cool a little Pentium G645...:geek:
    Goatee likes this.
  5. Goatee
    Goatee Multimodder
    19 Apr 2015
    Yep, I'm quite pleased actually. I ordered a longer but shorter 10mm heatsink from China. Will try expanding it out and fitting some smaller fans when that arrives.
  6. Goatee
    Goatee Multimodder
    19 Apr 2015
    Here is a mini-update.
    I mounted the case to my computer cabinet. Its not painted (the cabinet) and the build isn't finished yet but I'm really pleased with how it looks so far.
    Yaka likes this.
  7. Brett89
    Brett89 Minimodder
    15 Dec 2005
    Love rack-mount builds. I love that you're taking a 1U chassis and doing something else!
  8. TechnoMod87
    TechnoMod87 What's a Dremel?
    13 Nov 2012
    I hate the color of the fans noctua :miffed: but performarce are fantastic !
  9. MLyons
    3 Mar 2017
    I thought they sold black ones now
  10. Arboreal
    21 Jan 2011
    They do, but AFAIK they are 'Industrial' spec, not just black variants of the (in)famous Coffee 'n' Cream ones.
    Similarly, the 2 tone grey 'Redux' range are not the same as the main ones, they are the previous generation of fans in a new colour scheme, and don't have the accessories supplied with them
    like the speed drop resistor leads and rubber mount pins.
  11. Goatee
    Goatee Multimodder
    19 Apr 2015
    Yep, the baby puke and post curry brown are still in my opinion the best. I have kind of grown attached to them now.
    Arboreal likes this.
  12. MLyons
    3 Mar 2017
    I wasn't aware of those tweaks. Does anyone have experience with the EK fans? They seem to be getting quite a bit of praise online but I've not personally worked with them.
  13. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Aye, the main point of the Redux range is that they're cheaper because they don't come with all of the bells and whistles, so no low-noise adaptors, anti-vibration mounts or fan extension leads. Just the fan in the box, basically. And in terms of performance they're not quite the same as the latest and greatest standard Noctua efforts (although still very decent indeed).
    Personally, I don't mind the classic Noctua colour scheme, and I can't see them inside my case anyway :D Actually, that's a lie, I can just make out the side-panel fan on my M1, but only the "cream" part and not the "coffee" bit :D
  14. nOracle
    nOracle What's a Dremel?
    14 Nov 2006
    There's the Chromax range too, in black with swapable coloured anti vibration pads
  15. MLyons
    3 Mar 2017
    I guess these also aren't the top end ones.
  16. Arboreal
    21 Jan 2011
    Ahem,#CoffeeNCreamMasterrace surely...
    They do take a lot of beating and the new ones with Sterrox® liquid-crystal polymer blades are really excellent, I hear.
    Low-noise adaptors, that's what I was trying to say....
    Ditto on the not seeing them, (but they ARE there), I am still going to change the 92 and 120 ones in my M1 to Redux, because Grey
  17. nOracle
    14 Nov 2006
    Don't have time to compare the specs right not, but the blurb says "It ranges from chromax editions of the signature NF-A15, NF-A14, NF-F12 and NF-S12A", which i think ar the standard brown versions.
  18. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    The Chromax fans are the same as the brown versions but don't offer such a wide selection. In 120mm size they only offer high airflow and static pressure versions. I have a couple and they are awesome, if a tad pricey. They don't come with ULNA or extension cables etc but do come with the different coloured rubber pads.
    Source: https://noctua.at/en/products/fan/buying-guide
  19. TechnoMod87
    13 Nov 2012
    yes but unfortunately not in all models
  20. hayate89
    hayate89 What's a Dremel?
    19 Nov 2015
    mmmm i dont read the temp
