Mini - itx graphics issues?
Discussion in 'Tech Support' started by Mhiran, 15 May 2007.
  1. Mhiran
    Mhiran What's a Dremel?
    8 Dec 2002
    Hello there.. I have a Jetway J7F4 Dual Gigabit LAN 1.5GHz and I wish to run a monitor which takes a vga input (as standard) and a screen powered by composite connection. Now the motherboard has both connections, but I was wondering if there was any way of making both screens work at the same time?
    Thanks
    Mhiran
  2. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    What os are you using because my ITX M10K runs duel screen (stretched and double) on both linux and windows but im using the CL266(?) graphics chip.
  3. Mhiran
    8 Dec 2002
    Its Windows Xp Home Edition...
  4. AJB2K3
    12 Dec 2005
    If youve update the driver do to display properties>settings>advance and an option should appear for setting deul screen.
    BTW is the composite a shared digital optical out/compostie? if so you may need to alter the bios.
  5. culley
    culley What's a Dremel?
    12 Jul 2006
    this is in the wrong section
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Moved to TekSup.
