Mini-ITX Project <<pics fixed>>
Discussion in 'Project Logs' started by Shinymod, 12 Mar 2005.
  1. Shinymod
    Shinymod What's a Dremel?
    20 Dec 2003
    OK so I got lots on the go at the moment (mainly over at moddin.net forums) but one thing that's getting done right now is the Mini-ITX PC I'm building for my dad. He has a yacht and wants something to run the navigation software on. So here it is so far...
    A shot of all the hardware
    The mobo with clip in 12V-12V PSU and WLAN card
    The alu mobo tray it's mounted on, that's the start of the case [:)]
    The next day's progress:
    The reciever for the wireless keyboard and mouse before...
    And after the Shinymod treatment [;)]
    With the rest of the kit
    Motherboard tray with the hole cut for the cables
    Where the cables go: The hard drive through the 2.5" to IDE converter (mounted underneath the mobo), and the laptop CD to IDE converter. Note the nuts holding the mobo standoffs nice and tight.
    The cables poked through to the mobo side
    Test fit with the mobo, laptop CD and cables in place
    The next day's; this time I've mocked up a little of the construction in ProDesktop:
    The base plate and motherboard tray assembly.
    The full frame.
    That should give you some idea of the construction.
    The next day:
    It's s*xy, it's mesh, it's an I/O plate! quite proud of this idea [:)]
    It's not so s*xy looking, it took an hour to do, it's Mk.2 since I messed the first pair up... and it's mobo tray support. Not bent yet, but believe me it was harder than it looks to make.
    LEDs and holders that arrived from maplin today
    Close-up
    The Uber s*xy power button also from maplin
    That's it so far, but watch this space!
  2. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Very tidy work, I'm sure your dad will love it :D Do you have any plans to make a perspex cover for the mesh i/o shield? Protective cover and still the mesh pimpness :hip:
  3. Shinymod
    20 Dec 2003
    I had plans to make a splash shield for the I/O plate but now you mention it I could make it look so damn sexy if I made it out of plexi.....!! GOOD THINKING BATMAN!
  4. BiG Kahuna
    BiG Kahuna What's a Dremel?
    14 Aug 2004
    Looks really great so far, looking forward to the next updates :thumb: :dremel:
  5. Dayains
    Dayains Notamodder
    18 Dec 2002
    Looking great as always shiny :D
  6. Shinymod
    20 Dec 2003
    thank you all :) there should be another update either today or tomorrow, I've got a little more done
  7. Menthor
    Menthor What's a Dremel?
    26 Aug 2003
    dunno if it's only my problem, but pictures are loading kinda slowly
  8. Leeum
    16 Feb 2004
    Must be you mate, nice and fast my end :D
  9. Shinymod
    20 Dec 2003
    That's probably the webserver... I need to sort it out :sigh: anyway, not sure if I will have an update today after all... not got enough done :waah:
  10. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Can't see the pics (broadband).
  11. Shinymod
    20 Dec 2003
