Modding Mini-mod: Logitech wireless keyboard
Discussion in 'Modding' started by LuitvD, 30 Sep 2006.
  1. LuitvD
    LuitvD What's a Dremel?
    13 Aug 2006
    I took this baby:
    Ripped it apart (as in the picture above) and started cleaning the keys and the top-board, which were just absurdly dirty.
    When I had all the keys out I had an idea. You can see a can of spraypaint laying next to the keyboard, and I decided to use it, and ended up with this:
    I'm very happy with the color, the keys look really nice and white now :)
    Also thinking of making my current mod this color
    One question for you guys (and girls, ofcourse):
    What to do with the currently greyish-blue part? Make it the same color? White? Yellow? Red?
  2. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    i think it had good contrast :)
  3. mattthegamer463
    26 Nov 2004
    Hmm, I've got a hideously yellowed and stained keyboard here, this would make a nice mini- project for the weekend...
  4. LuitvD
    13 Aug 2006
    actually, you could do more then one in a weekend... This job was like 10 minutes to take this thing apart and clean the to-be-painted part for spraying (under warm water with dish-washing soap), half an hour of spraying (pauses of 5-10 minutes between layers, had like 5 layers), another hour for cleaning all the keys (just with a general cleaning spray thing and a cloth), 10 hours of waiting for the paint to get tough (so you can do the previous steps for another 6 keyboards in this amount of time)
    I was busy less than 1,5 hours :) painting the whole keyboard would take about 2 hours, and 10-15 hours of waiting (depends on the type of paint)
    think I'll do my mouse tomorrow :) really looking forward to doing this to my computer :D
    (just bought 2 cans of high-quality spraypaint (that colour) for 8 euros :D )
  5. mattthegamer463
    26 Nov 2004
    Well on mine I want to swap the LEDs, paint the keys, and mod it a bit so it will take a bit longer.
  6. LuitvD
    13 Aug 2006
    do post pictures of before and after :)
    why not make this the keyboard-mod thread? :p
  7. mattthegamer463
    26 Nov 2004
    Heres a before shot of the victim.
    A 10 year old IBM PS/2 keyboard, heavily stained and yellowed, and in dire need of a paintjob. Has a really nice smooth typing action though, I can type faster on it than any other keyboard I've ever used.
    Plan is, black blank keys, red body, black cord, red connector on cord.
  8. Upriverpaddler
    Upriverpaddler What's a Dremel?
    29 Jan 2005
    You can put 2 very light coats of a very light color on the keys and the letters will still show thru. I did this with yellow on the keys once.
  9. mattthegamer463
    26 Nov 2004
    Yeah but I want to paint them black, and I don't need the labels, I know where the keys are fine.
  10. LuitvD
    13 Aug 2006
    wohoo, the good old IBM keyboard :) Those really are inbreakable. I once had one... Have no idea where it is right now :(
    Going to paint my mouse soon... maybe tomorrow :) the now-blue keyboard types very well, might consider painting everything before the lan next weekend, to get there all-blue :)
  11. LuitvD
    13 Aug 2006
    painted my mouse now, turned out even nicer then I could hope for :D
    Actually, in real life it looks even better then on this picture, because of the light... IT'S AWESOME
    I'm glad I got the thumb-pad back on that nicely :D this mini-mod almost went too perfectly :p
  12. mattthegamer463
    26 Nov 2004
    Some pics of my keyboard during the painting:
    ^ Stuff laid out in the garage.
    ^ The red WASD keys, just to be cool.
    Once those WASD keys have dried ill post some pics of the finished thing, but some of the keys need touchup as I missed some spots on the 500+ surfaces I needed to paint. About 6 keys are too ugly to be let off the hook.
  13. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Lmao, I might do that to one of my old keyboards. That is, paint it black/dark grey and paint the main gaming keys red. AWESOME idea! :D
  14. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    you could use candy paint to color the keys and still see the letters/symbols. it would look especially cool if it was a black keyboard with white lettering, then only the lettering would be colored. i might have to try this...
    edit: also, luitvd, you might want to wet-sand your paint with fairly high-grit sandpaper to get rid of the "orange peel" that it looks like you have on your keyboard. it woud make it very glossy
  15. LuitvD
    13 Aug 2006
    yeah, I know, but you have to wait for like a month to do that for the best result right? I was going to do that :) hate the orange-peeling look :p
  16. itsjustacompaq
    7 Sep 2006
    what paint did you use? if it is automotive paint, just lay it out in the sun for a day, then you're good. this cures it faster.
  17. LuitvD
    13 Aug 2006
    it's some standard spray-paint... I'll just wait 2 more weeks, and then I'll wetsand it straight
  18. mattthegamer463
    26 Nov 2004
    I typically just sand my crap in 24 hours. Haven't had a problem yet.
    My keyboard is finished (except for some keys that need touchup.)
  19. LuitvD
    13 Aug 2006
    I think you sprayed too close to the keys... Or you didn't clean them enaugh... :p
    I just painted my remote too :D check it out:
    And a shot of all three devices together :)
  20. mattthegamer463
    26 Nov 2004
    So its a painting war now, is it?
    How could I miss spots by painting too close to the keys? Also, I scrubbed each one individually with warm soapy water and a brush. They were clean enough to do surgery on.
