Guides Mini Mods: "Modular" Fan Cabling
Discussion in 'Article Discussion' started by bit-tech, 27 Feb 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Cheapskate
    13 May 2007
    All this talk of strippers, and not one decent lap dance picture. I'm disappointed.
    You should do a guide on pin and connector types for most common components. Thanks to USB 3, we are up to three different pin types/pitch.
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    That’s a solid suggestion, have a few I’d like to work out myself actually so would make for a good opportunity. With all the lighting headers out nowadays there are a billion types in use currently it seems.
  4. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Can you share the names of the components which you use?
    Specifically I cannot find the plugs and sockets without having to buy new ones.
    Can you even buy them separately? I guess you must be able to...
Tags: Add Tags
