PSU Minimum PSU needed?
Discussion in 'Hardware' started by mattyh1995, 18 Feb 2012.
  1. mattyh1995
    mattyh1995 Minimodder
    1 Oct 2011
    Whats the minimum power needed for 2x560's, i5 2500, ATX mobo with 2*2GB DDR3 RAM, 1 HDD and one DVD/CD RW drive.
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    I would say a decent 600Watt should do you proud.
  3. mattyh1995
    1 Oct 2011
    Thanks. Seen all different all over google :S
    Been recommended an 850W on one calculator, a 700W on another.. :L
  4. Blogins
    3 Aug 2010
  5. mattyh1995
    1 Oct 2011
    Nice one mate, thanks ^^
  6. xxxsonic1971
    xxxsonic1971 W.O.T xxxsonic1971
    5 Dec 2010
    hello, i got a similar question really...would an xfx 850w psu power a 5970+5850?
  7. AoE
    AoE What's a Dremel?
    4 Oct 2011
    600w corsair
  8. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    Well i would get a good 750W PSU.. which should easily handle your config and should also keep it future proofed :)
  9. The_Crapman
    5 Dec 2011
  10. TheBigFella
    TheBigFella U jelly?
    20 Feb 2012
    Go for 600w if you are not going to OC, but if you are going to OC then get 700w PSU:thumb:
    I your place i would buy corsair AX650 PSU, it is great but for me too expensive...
