Hardware Mionix Naos 3200 Review
Discussion in 'Article Discussion' started by Claave, 24 Jan 2011.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. Jipa
    5 Feb 2004
    The shape is just perfect. No other word for it..
    Don't be fooled by the unknown brand either, I've had my 5000 for a year now, still looks brand new and no problems whatsoever (except damn cat hair in the sensor, but that isn't the mouse's fault :p )
  3. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    I guess you have to expect a cat to go for a mouse :)
  4. boggsi
    boggsi What's a Dremel?
    30 Aug 2005
    I'll get your coat.
    Thanks for the review, not the most hotly debated items but very nice to see peripheral reviews in bit-tech :)
  5. Fantus
    Fantus Nothing to see here...
    25 Jun 2010
    Brilliant range of Mice. I've got the 5000 and can't fault it. The DPI is ridiculous but I've never pushed it further than 4000. Little things like the adjustable lift distance sensitivity make a huge difference in how a mouse feels to use and these have it spot on. The only thing I did find is that the led under your palm makes your hand a bit warm; it's all good though 'cos you can just turn it off :D
  6. kzinti1
    kzinti1 What's a Dremel?
    13 Apr 2010
    What's does "polling rate" mean? I'm not familiar with that term. I wouldn't ask but just a few minutes ago I read a review of an AsRock mobo that has a usb/mouse port that has an adjustable "polling rate" from 500 to 1,000 and was just wondering.
  7. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    I love my 5000. Just ordered the new Mionix Propus 380 mouse mat to go with it.
  8. uz1_l0v3r
    uz1_l0v3r What's a Dremel?
    22 Sep 2009
    If memory serves me correctly, it's to do with how often the OS "talks" or polls your mouse. I guess that higher polling rates means greater accuracy by the OS in interpretation of your movements.
  9. kzinti1
    13 Apr 2010
    Thanks for the info!
  10. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    The shape is really alike the Qpad 5K and the Steelseries Ikari, very comfortable.
  11. Elton
    23 Jan 2009
    It's like the Ikari? I'm sold!
  12. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    I would love to see a wireless version of these and for me would most definitely be one to buy.
    Update: I contacted Mionix and asked if they were looking to make a Wireless version of their mice and it does indeed seem that they have a prototype design that they demonstrated at CES 2014 and they provided this link for it: http://mionix.net/concepts/concept-px/
    I hope someones at Bit-Tech gets to read this and can get a review sample is when one becomes available as I think they have a really solid concept and has been a while since I have been excited by something as simple as a mouse since I last bought a Logitech one.
Tags: Add Tags
