Windows mIRC question
Discussion in 'Software' started by Soulfly22583, 4 May 2005.
  1. Soulfly22583
    Soulfly22583 What's a Dremel?
    12 Jan 2004
    1) I did use search and nothing came up
    2) I read through the mIRC for dummies guide in this forum and didnt see this point
    Is it possible to connect mIRC to two servers at once? Say i want to chat with everyone on the bit-tech channel on quakenet... but i wanted to talk to some other friends over on slashnet.... can this be done?
  2. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    Yes, it's REALLY easy. You can create 2 connections & choose whichever networks you like. I can't actually remember the exact buttons because I don't use mIRC, but I'm sure someone will provide it in a sec.
  3. Soulfly22583
    12 Jan 2004
    good to know, thank you Hex =)
  4. Barry
    Barry What's a Dremel?
    23 Jan 2005
    Best way is to just install NN script, that gives you the option for multipul networks!
  5. Soulfly22583
    12 Jan 2004
    and where would one find the NN script
    *edit - found it, am now trying to get it all set up... thanks bud.
    *edit 2 - got it up and running... thank you for the help.
  6. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    You can simply type /s -m irc.quakenet.org to connect to a new server.
  7. tk421
    tk421 Idiot.
    15 Jan 2002
    other clients, such as trillian or xchat make multiple server connections quite easy. i used to use xchat for linux, but iirc there is a windows version available.
    i use trillian in windows, but the only irc'ing i do is the bit channel, and only rarely.
