Modding 101 part 2
Discussion in 'Article Discussion' started by macroman, 7 Jan 2004.
  1. macroman
    macroman The One
    3 Sep 2001
  2. Lazy
    Lazy Meow?
    13 Nov 2001
    I found double sided sticky to be a bit weak sometimes, duck tape seems far superiour (well my top window hasn't caved in... yet).
  3. couzo
    couzo What's a Dremel?
    26 Apr 2002
    Great finish to the edges I will remeber the wet dry and soap trick never thought of that!! I have used duck tape in the past but have just added a new window with hot glue it is a excellent finish and you can easily put the window off!!
    Nice work again macro
  4. macroman
    macroman The One
    3 Sep 2001
    The tape to use is about 2" wide and is the sort used for sticking down carpets. Pro carpet layers use it and believe me it really does stick! The "cheap" stuff sold in stationary shops is poor. ;)
  5. Lazy
    Lazy Meow?
    13 Nov 2001
    I got mine from focus do it all! :D
  6. macroman
    macroman The One
    3 Sep 2001
    Not to worry. So long as you learn from your mistake ;)
  7. graphixkid
    graphixkid What's a Dremel?
    20 Dec 2003
    Sweet article man! I'm seriously thinking of doing a top window now... Thank you!
  8. lord nicon21
    lord nicon21 sexy *******
    29 Sep 2003
    wow neat cutting i'm all over the place
Tags: Add Tags
