Guides Modding an Asus RT-AC5300 Wireless Router
Discussion in 'Article Discussion' started by bit-tech, 9 Aug 2017.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
    silk186 likes this.
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
    Flip it upside down and you have an RGB Spider as a Halloween decoration:lol:
    I like the mod on its own, but the Router? With that moar antennas design I'd probably decide to tuck it away out of sight rather than draw attention to it.
  3. Ljs
    Ljs Modder
    4 Sep 2009
    Could be worse.
  4. Guest-16
    Guest-16 Guest
    It's only going to get worse in future. You'll get more and more antennas as we roll from 5GHz AC --> 60GHz AD and 5G mmWave has 'array antennas' that are literally a small wall of tiny, directional antenna nodes. Every time you add a significantly different frequency you need new antennas.
  5. zerophase
    zerophase What's a Dremel?
    3 Jan 2019
    I'm trying to open mine to flash firmware by serial, and cannot see how to remove the motherboard to access the serial port on the other side. Seems like I just need to remove the rivets up top, but don't see how to get in to drill them out.
    How did you manage to get the screws out from up top, the ones just under the mobo for the top grill?
Tags: Add Tags
