Modding Modding the PSU
Discussion in 'Modding' started by NOMIS, 30 Nov 2004.
  1. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    How dangerous is it to take the cover off of the PSU and paint it, and to put a window(or 2) in it?
    I mean, surely just taking the metal off and leaving the actual components somewhere out of the way while you do it would not be a hassle? How dangerous is it!?!?
    Are the components inside it screwed to the metal? Or are they on some sort of board or something that is screwed to the metal cover? Also, would it be safer if you wore like rubber/electrician type gloves when you were pulling it apart :)?
    Cheers!
  2. noobidoo
    noobidoo What's a Dremel?
    8 Jun 2004
    the compunet's are not connected to metal!!!!! :duh:
  3. Skylined
    Skylined Minimodder
    3 May 2003
  4. NOMIS
    7 Jun 2004
    You sure that's the right thread? Looks like a project log to me :eyebrow:
    Will discharging the capacitators take away the risk of electric shock? Or lessen the power of it or what?
  5. Gumbatron
    Gumbatron What's a Dremel?
    18 Nov 2004
    Maybe this thread better demonstrates why we should discharge the Capacitors in our power supplies. :D
  6. Skylined
    Skylined Minimodder
    3 May 2003
    Yes, it's one of my projects, and if you take a look you'll see a bare PSU.
    All you have to do is discharge the capacitors, that's the only risky part.
  7. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    I've painted many PSU's, you can safely take off the Top cover with out even having to touch anything. The bottom part is a little more difficult, as the PSU pcb is screwed to it, along with the fan. Discharging the caps is always a good idea.
  8. NOMIS
    7 Jun 2004
    Okay so it is easy to take the top off then, but not the bottom. Does discharging the capacitators mean you can touch anything and there is no risk?
  9. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    i searched your proj. log (nice mod, btw :thumb: ) and couldnt find how to discharge the caps. which post is it in?
    thanks
    Z
  10. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    Amazing what a quick search turns up. :thumb:
  11. Skylined
    Skylined Minimodder
    3 May 2003
    You can take away the cover as well as the bottom part of the PSU.
    The only complicated part about removing the bottom part of the PSU is that you'll have to desolder the cables that go to the AC connector and then when everything is done you'll have to solder everything back, it's still an easy task.
    As Shadowspawn, use the Search option. ;)
  12. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    To discharge the caps , just run the ps with a fan plugged in a 4 pin molex and unplug the ps from the wall outlet the fan will spin for a second after the unplug, draining the caps and making it perfectly safe to play inside :thumb:
    For the non beleivers, this pic was taken right after i unscrewed the corner screws
  13. NOMIS
    7 Jun 2004
    Ahhh cheers for that dude, so basically the caps just hold some of the electricity in them, even though it is not turned on/running? But turning it on with the fan they use oup that electricity in the fan? Sweet, thanks for that.
    So once the fan has stopped they have been discharged?
  14. Kobalt
    26 Aug 2003
    Basically, they're like little storage and the fan uses it up till it's all gone that's why i can stick my fingers anywhere in the PSU after that.
    And imo the electrocution thing with a PC psu is highly exagerated,of course you have to be careful around plugged anything but let's face it , a psu is plugged into 110V (on my side of the pond lol) and delivers 12V, there's no voltage multiplicator in there like in those stigner sticks for cows so basically the highest jolt you ever going to get is 110V "IF" you leave it plugged in and play in it.
  15. NOMIS
    7 Jun 2004
    Cheers for the help dude, one more question now, is it safe to make a window in the psu cover, the same as you would with a side panel? Using double sided tape to stick it in and just your average plexiglass/perspex stuff?
    Would this cause problems?
    Thanks for all your help !
  16. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    to discharge the caps.. i was told this very simple way.. take the plug out.. and turn on your pc..
    i did it, and my pc actually went on for about a second.. not even plugged in.. its an antec truepower 550W, so i imagine it would have quite a kick if i got shocked
    hmm, psu's get very hot, so double sided tape might just end up... melting.. consider a few screws
  17. clocker
    clocker Shovel Ready
    21 Dec 2003
    Yes, it is safe to make a window...no, I would not use doublesided tape.
    I like to use GOOP ( in all of it's many varieties) which is a fast curing silicon adhesive to install windows.
    Just be sure there is no need to remove the plexi...GOOP is quite tenacious when used on a large surface area.
  18. NOMIS
    7 Jun 2004
    Oh yeah I never thought about the heat, thanks for that. Yeah I could use silicon we got lying around here, or I will just use screws. Thanks for that advice:thumb:
