Modding monitor disassmebly
Discussion in 'Modding' started by itsjustacompaq, 11 Dec 2006.
  1. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    does anyone know how to disassemble a compaq FP-5315 15" lcd monitor? i have searched goodle for schematics/instructions, and i cant find a thing. i have removed all the screws i can get at/see and it still feels as solid as ever. i want to paint it, but dont want to risk damaging the screen or connectors. please help
    here are some pics
  2. Devrethman
    Devrethman What's a Dremel?
    26 Jun 2006
    OEMs tend to hide screws behind stickers/pads/etc, have you tried taking stuff like that off and checking for hidden screws?
    Also, it probably has some kind of snapping mechanism that holds them together, try running something between the front and back section to try to unhook stuff like that. Not too hard though, cause else you'll break things.
  3. itsjustacompaq
    7 Sep 2006
    anyone have any experience with this monitor? i pulled all the pads off and unscrewed everything i could. i still cant find the magic screw that opens this thing.
  4. DougEdey
    5 Jul 2005
    It may have clips around the edges.
  5. Pre_Tender
    Pre_Tender What's a Dremel?
    8 Oct 2006
    most of them (at least the broken ones i've opened) have indeed some sort of clips alongside of the edges on the inside of the housing of the monitor
  6. overdosedelusion
    overdosedelusion I mostly come at night, mostly..
    29 Oct 2006
    it will have clips if there are no more screws, best way to get it off is with the same method you remove a bicycle tire. Otherwise youll find they snap right back into place.
  7. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    Try to find an old sturdy pocketknife or use a small flat head screwdriver to get inbetween the plastic pieces and run it along the edge until you pop the clips. You will be able to tell where there are clips because the plastic will be held together really good in that location, then using a prying motion just pop the clip.
    Once apart the panel should just pop right back together, but if not that is also what those screws are probably for.
