I recently installed a Radeon 4350 which I use with an IBM E74 17" CRT (on the DVI port with D-sub converter) as primary display and an HP1502 15" LCD (on the D-sub port). The problem is the card identifies both monitors as being HP1502s. I have tried everything I can think of in CCC to get it working properly but nothing works. Has anyone got any ideas to fix this.
Howver, surely if both monitors are detected as 15", then the 17" won't be able to run at 1280x1024? I spose you could untick the "hide unsupported res" button.
