Displays Monitor mount/arms
Discussion in 'Hardware' started by MadGinga, 6 Jan 2021.
  1. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    Hi There;
    Its looking like i'll be moving to a 3 display setup (to accommodate my work PC and personal system on one desk - i dont have space to separate); so looking for advice/recommendations on a mounting system for 3 24" monitors (2x Dell U2417H and 1x Dell U2412M) so that i can free up desk space under the screens for cables/keyboards/junk/etc.
    Cheers,
    MadG
  2. BA_13
    BA_13 Minimodder
    2 Sep 2011
    I use an Artic Z2-Pro and am very happy with it, currently it supports a 35" ultra wide and a 19" 1080.
    It is very sturdy and I'm happy with it, only point to note is to ensure it will hold the monitor high enough for you, I have it at the higest setting and it is about right but I'd have to buy an extension if I needed it higher.
    The link to the 3 monitor mount below is the same model I use.
    https://www.arctic.de/en/Z3-Pro-Gen-3/AEMNT00051A
  3. blackerthanblack
    blackerthanblack Minimodder
    17 Sep 2004
    I'm sure I'll be reading this the wrong way, but can you not use multiple inputs in the monitors to switch between work and home machines for just 1/2 monitors? Or is that you're getting 3 monitors anyway?
  4. VictorianBloke
    VictorianBloke Man in a box
    31 Oct 2007
    +1 for the Arctic. My Z2's holding a 27"er and a 22" in portrait. The stand was sturdier than the desk I clamped it to... desk has since been reinforced and is all rock solid.
  5. MadGinga
    19 Mar 2009
    I can and I will for some aspects, but ideally I want to be able to have my home machines on one screen (gaming and server) so i can access home related guff/music/netflix/etc., and then use two screens for work rather than having to use the laptop as a secondary screen...
    awesome, will take a look :)
