monitor problem
Discussion in 'Hardware' started by finboz, 16 Jan 2006.
  1. finboz
    finboz What's a Dremel?
    11 Aug 2004
    my monitor starts making a wierd high piched noise when i start playing css or cod2 but is ok when browsing. basically i was wondering if it is on the way out or has anyone else experienced this problem.
  2. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Only ever had that problem once, on an old CRT, it died shortly after.
    RIP old monitor.
    When you play CS do you use a different resolution to that of your desktop ?
    I found when mine was about to go, if I changed the res it would cure it for a short time, but it was a matter of weeks only.
    Sounds like the caps are about to blow.
  3. Arkuden
    Arkuden mow?
    9 Jul 2004
    yeah i had an older monitor do that as well it went poof about a month later.
  4. hitman012
    hitman012 Minimodder
    6 May 2005
    Yeah, this happened to me on a CRT which expired about a month down the line. Try changing resolutions to make the pitch higher/lower so that it's not so annoying.
