Displays Monitor recommendation
Discussion in 'Hardware' started by DK63, 6 Apr 2020.
  1. DK63
    DK63 Resident magpie
    8 Sep 2009
    I currently have an Acer VG270U Pbmiipx monitor, 144Hz refresh, 2560x1440 resolution. I'm very happy with it and want a second 27in. Problem is, mine has the power switch on the right hand side, so I can't mount a second monitor against the right side, and my desk layout means a monitor to the left is a no go. Can anyone recommend a suitable, same spec, monitor where the power switch is accessable from the bottom please? Must have DP connector. Thanks.
  2. sandys
    sandys Multimodder
    26 Mar 2006
    Depending on style of screen can you use it upside down using options in driver to flip image?
    Or don't use power switch and just let it sleep.
  3. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Whats your budget?
  4. DK63
    8 Sep 2009
    I have thought of letting it just drop into standby but I like to save energy where I can.
    Budget, ideally, around £250, but willing to stretch if a deal comes along.
