Displays Monitor Repair
Discussion in 'Tech Support' started by Davesbeard, 17 Sep 2010.
  1. Davesbeard
    Davesbeard What's a Dremel?
    17 Sep 2010
    Hi guys, new to the forum so hello!
    I've had a Hyundai N91W monitor for about 4 years now which i'm using as a second screen. However this morning it seems to have died on me. An image appears very briefly when the screen is turned on/woken but then almost dissapears. I can see the image is being displayed but it is extremely dark. I've googled it a bit and come across a few people with the same problem and it seems to be the monitors Inverter that is knackered. I'm quite happy replacing it myself but i can't find anywhere to get hold of the part. You guys got any ideas?
    Cheers
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    take the inverter out, and google the part number.
    or try typing the part number in on this website
    bulldogjeff likes this.
  3. bulldogjeff
    2 Mar 2010
    Yep totally agreed, this is the way t go with it.
    Teelzebub likes this.
  4. Gryphon
    Gryphon What's a Dremel?
    24 Apr 2009
    I had a quick google and couldnt find any guides or any other info on the inverter, but it should be a relativley straight forward job, assuming you can get a replacement inverter.
