Graphics Monitor scaling issues on AMD graphics card
Discussion in 'Hardware' started by PortalBen, 22 Jun 2013.
  1. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Does the display itself have any over/underscan options in the internal set up if it has one? Worth checking, maybe it is doing something dumb internally. Otherwise basically I agree with if you can use any other connection type than hdmi, unless hdmi is the only digital connection on the display I wouldn't use it.
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    Have you tried pressing the auto button on your monitor?
  3. law99
    law99 Custom User Title
    24 Sep 2009
    On my Samsung TV, unless you select one of the manual options, it does exactly what you are saying. On my Panasonic one... Good luck with that. No amount of tinkery works. Use the VGA in and everything is hunky dory...
  4. PortalBen
    PortalBen Minimodder
    22 Nov 2009
    Updating chipset drivers didn't work but luckily I found an old vga cable which I connected to my graphics card with a vga to dvi adaptor. The image fills the screen properly but isn't as sharp as with the HDMI cable. It'll do for now though because at least I can see everything. There's no option on my monitor for underscan/overscan though.
    Thanks for all your suggestions :)
  5. teppic
    teppic What's a Dremel?
    18 Jul 2011
    It might all be fixed if you can use a DVI cable.
    (Or get a new monitor, your card is extremely happy at 1080p :) )
  6. PortalBen
    22 Nov 2009
    Yeah I think I'll get a dvi cable tomorrow, I've actually got a 23inch 1080p monitor but I don't have it with me at the moment unfortunately.
    Thanks for taking all the time to help :)
