Displays Monitor VA1912wb not turning on
Discussion in 'Tech Support' started by OverQloker, 14 Apr 2009.
  1. OverQloker
    OverQloker Haven't Touched No Dremel
    5 Jun 2008
    My Viewsonic VA1912wb monitor stopped turning on since yesterday though the status LED on the monitor changes its state accordingly with the computer state.
    As it has dual inputs (VGA, DVI-D) i tried them both; i also ruled out a graphic card issue as its working with another monitor (on VGA though as DVI port was not present, mine is usually setup with DVI)
    I've heard about the CCFL lamps in monitors giving up, but is there a way to know for sure. i can't seem to see anything..
    Also the initial screen when the monitor is turned on (No signal found, Powering down now) is not displayed, but as before, the status LED changes
    any help/insight would be appreciated
    ViewSonic VA1912wb, 19" wide 16:10 TN-Multimedia Digital LCD Display
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Try with pointing the screen with a bright flashlight and see if you can see any shade of an image on it.
    If you can see a picture, then the CCFL is indeed dead.
  3. OverQloker
    5 Jun 2008
    Dead CCFL it is....
    yes i can.....:duh: so now its off to the retailer for a repair.......
    hope it's replaced.. was eyeing the Viewsonic VX2260wm - 1920x1080 in 22"..... :naughty:
