Cooling MOSFET heatpipes possible?
Discussion in 'Hardware' started by scotty6435, 27 Oct 2004.
  1. scotty6435
    scotty6435 What's a Dremel?
    4 Sep 2004
    I'm not sure if this has been thought of before but does anyone think it is possible to use heatpipes to cool MOSFETs? Possibly modifying a GFX card heatpipe & sinks would help achieve a more stable overclock without the water flow restriction/fan noise.
  2. Heavytank2
    Heavytank2 What's a Dremel?
    10 Oct 2003
    Heatpipes are made on a custom basis. They are made and filled for their intended use and would most likely be horribly inefficent in another application.
    Unless you got massively lucky and your mosfets ran the same conditions/temps/etc as your video.
  3. Nexxo
    23 Oct 2001
    Still, the idea is good. Perhaps some mobo manufacturer will release one in the future with that feature on it. Would be nice...
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    A chopped up sink does the job nicely with a little airflow :) As long as the base is fairly thin that is :D
  5. scotty6435
    4 Sep 2004
    Yeah, I've got some old pentium heatsinks to cut into sinks but heatpipes seem to be the perfect addition to the extreme overclocking mobo. Might make a good add-on to some current ones if any companies are reading this :D I'd like a watercooled mosfet cooler but they're pretty restricting on flow especially as I will eventually have 5 blocks fitted :)
  6. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
  7. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    Yeah I agree. Althought I reckon it wouldnt be cheap.
    Also Tulatin, that thing looks amazing. I bet zalman will be into it soon.
    Also that is a lovely mobo. I had one of those 3d cpu coolers. They are very pretty, but not a --silent run.
  8. kipkool
    kipkool What's a Dremel?
    11 Jun 2004
    heatsinks is a good solution even for high o/c
    wc is the most perform and I think it doesn't provoke a big restriction flow by making a very few restriction wb :thumb:
  9. Lord_A
    Lord_A Boom baby!
    23 Mar 2002
    That looks pretty damn sweet, I have a Gigabyte 8KNXP which also has that dual power board, it came with a heatsink & fan which I removed and replaced with custom heatsinks.
    I'd like to know just how heavy that heatpipe solution is though, because the dual-power board is held in place by a small clip and it is rather flimsy.
    /end of slightly off topic post :p
