Modding motorized LCD monitor
Discussion in 'Modding' started by zachjowi, 6 Jan 2006.
  1. zachjowi
    zachjowi What's a Dremel?
    15 Jan 2005
    Does anyone have any idea how to get a Sony LCd monitor to be motorized so that it can be folded flat, then pulled in/out of a single drive bay?
  2. bluknight
    bluknight What's a Dremel?
    4 Jul 2005
    Maybe a stepper motor and some nice mechanics?
    Maybe either something to push into the back of the lcd screen (and a hinge directly above said thing) so that as it goes out the screen would go flat.
    Either that, or maybe strings attached to the corners the screen, with a similar hing placement (like 1/4 of the way down or something), and then when the motor lets out the string, it would make it vertical, and when pulled back in it would make it horizontal.
    You could then have another motor to pull the whole assembly into the drive bay, or maybe with the second idea have some more mechanics to make the string pull it into the bay after it is flat.
  3. ARM
    ARM Minimodder
    15 Sep 2004
  4. zachjowi
    15 Jan 2005
  5. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Just a little bit of info, im too working on something simmilare but have just found that the hinge need replacing/ modifying for the position i need.
  6. zachjowi
    15 Jan 2005
    I would like to use my Sony PS1 LCD monitor to have as a screen in one of the 5.25 drive bays. It needs to beable to come out of the bay then pivot up so that it will be infront of the two drives abouve it.
  7. AJB2K3
    12 Dec 2005
    You will be hard pushed because of the round pcb.
  8. DR_D
    DR_D What's a Dremel?
    8 Nov 2005
    i don't think it would be any different than using a rectangular lcd. You would just need to make a mount for the display to sit on.
  9. zachjowi
    15 Jan 2005
    thats what I thought. I'll make a square mount out of c channel metal or something.
  10. AJB2K3
    12 Dec 2005
    Have you seen its circuit board yet?
  11. zachjowi
    15 Jan 2005
    Yes I have two of them
