Cooling Mounting a Rad
Discussion in 'Hardware' started by HQ08-Modder, 24 Nov 2003.
  1. HQ08-Modder
    HQ08-Modder What's a Dremel?
    14 Nov 2003
    How exactly do you mount your rad if your palcing it in front bottem aprt of the case. I've run into that problem and yer.
    My case is a Hq-08 if that helps and the rad is a big arse camry '89 heatercore.
  2. Risky
    Risky Modder
    10 Sep 2001
    what mountings have you got on the rad itself?
  3. mushky
    mushky gimme snails
    24 Mar 2003
    you could mount the fan to the case, then the rad to the fan
    RAD¦FAN¦CASE FRONT
    sort of thing
  4. HQ08-Modder
    14 Nov 2003
    The rad don't have no moutnign holes.
    Ill probally do the
    RAD¦FAN¦CASE FRONT
    idea.
  5. Risky
    Risky Modder
    10 Sep 2001
  6. Haddy
    Haddy World Domination
    22 Jan 2002
    zippy ties...duck tape....bubble gum....so many different methods to chose from
  7. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    I used some threaded stud and bent it to shape, I put some spiral warp on it to stop it marking the rad. :dremel:
    This is a shot from the front:
    I then used a small piece of metal stuck at the bottom between the barbs to stop it slidding out. It's been tranported loads of times to mates house and to LAN's an hasn't budged :D
    Just the way I did it :thumb:
