Peripherals Mouse issues, help!
Discussion in 'Tech Support' started by KENDIK, 3 Oct 2009.
  1. KENDIK
    KENDIK What's a Dremel?
    3 Oct 2009
    Help please! This is been driving me insame now :wallbash:
    I've reinstalled XP with all the updates, installed all motherboard drivers using wireless mouse.
    All is working correctly, but when I try to plug in a standard optical mouse, it is recognised, I can see that the drivers are installing from the baloon pop up, then the mouse briefly works for a couple of seconds, then it stops.
    The keyboard on the other hand works perfectly. I have tried a couple of different ones in various USB ports, with the same result. Even tried PS2 mouse, but no avail.
    There is nothing else plugged in to any USB ports at all.
    Can you suggest any solution please?
  2. doggeh
    doggeh What's a Dremel?
    27 Apr 2009
    Well a PS2 mouse will need to be plugged in BEFORE you turn on the machine for it to be recognised... It will not work if you plug it in after the machine has booted up.
    Try that and if the PS2 mouse works it sounds like your USB optical mouse is simply broken.
  3. KENDIK
    3 Oct 2009
    Sorry but i do know that the PS2 mouse needs to be plugged in BEFORE the system is on.
    I have also tried 4 x different mouses in second PC, and they all worked fine ( 2x brand new Logitech's, Microsoft optical and Apple Mighty Mouse ).
    CHecked event viewer, but no errors on it. Nothing else is plugged in to spare USB ports as well. No addiditonal PC cards, that can conflict with the system.
  4. doggeh
    27 Apr 2009
    Well that is truly bizarre :confused:
    The next thing I'd check is that the motherboard drivers you've installed are actually the correct ones for your exact model of motherboard. Lots of drivers may work but try installing the ones off the CD that came with the board, they may be older but they'll be guaranteed to rule out driver issues at least.
    Other than that I'm stumped, sorry!
    thehippoz likes this.
  5. KENDIK
    3 Oct 2009
    Installed all the drivers from the CD that came with the motherboard.
    this is the most bizzare problem i've had in my whole IT career. I know that i could possibly reinstall OS and see what happens, but i want to know why it happen in a first place.
  6. doggeh
    27 Apr 2009
    Have you checked in Device Manager that there are no problematic devices? i.e. devices with a yellow highlight beside them?
  7. KENDIK
    3 Oct 2009
    Checked this as well, all looks fine
  8. doggeh
    27 Apr 2009
    Yep sorry mate I'm stumped then.
  9. dushuai
    dushuai What's a Dremel?
    9 Sep 2009
    check out the mainboard,I think the north bridge may be the problem,may be the driver or hardware problem if your USB mouse and PS2 mouse can`t work properly both,the way is using an USB camera or another thing to check the USB is OK.
  10. MorpheusUK
    MorpheusUK a Noob that knows something
    24 Sep 2009
    Here's a suggestion.
    Go to Device Manager -> Mice and other pointing devices -> and Uninstall the mouse.
    Then reboot with the mouse plugged in and see if that works.
    To me it sounds like a miss installed mouse driver.
  11. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    +1, was gonna suggest that aswell.
  12. B3CK
    B3CK Minimodder
    14 Jun 2004
    are you on a glass surface for the mouse? Do you have 'ball' mouse to try?
  13. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    I had a similar situation (though with an MCE remote). I ended up removing everything related to USB in the device manager - including the Universal Serial Bus controllers. On reboot it took some time for Windows to rebuild it all but it all worked.
