A/V Movable projector mounts?
Discussion in 'Hardware' started by airchie, 16 Jul 2009.
  1. airchie
    airchie What's a Dremel?
    22 Mar 2005
    Hi guys,
    I have an interesting issue at work and wondered if anyone had solved a similar issue and may be able to shed some light.
    We have three collaboration rooms being set up, each has a large projector which is going to be above a large table which weighs over a quarter of a tonne!
    When we need to swap a bulb in the projector, we need to set up scaffolding over the table with arm-rails etc due to the HSSE issues involved with working at height.
    I was thinking, what would be easier is to have the projectors mounted on some sort of rig that allows the projector to swing down to a safe height beside the desk.
    Just like a basic hinged arm, preferably powered, that can be operated to bring the projector to an easy to access position for maintenance and then can be activated to place it back in it's active position on the roof.
    Anyone seen anything like that?
  2. airchie
    22 Mar 2005
    Bump?
    Am I seeking the holy-grail of projector mounts that nobody's invented yet? :D
  3. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    Why is the projector so bloody big!?!
    Sorry, no idea about your question though. :)
  4. Sp!
    Sp! Minimodder
    6 Dec 2002
  5. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    er i think it's the table that weighs 250kg, and is therefore unmovable to allow for more easy access to PJ.
    but i can't think of anything to help here.
  6. airchie
    22 Mar 2005
    Yep, you're right Fod.
    The problem is that the projector is directly above the table and the table is HEAVY.
    Normally that would be perfect, just stand on the table and change the bulb.
    But, in this HSSE-addicted time we live in, that's deemed unsafe.
    So we have to go arrange scaffolding with a handrail to go over the table to change the bulb... :duh:
    I was hoping to find something that can swing down the projector so its easily accessable for simple maintenance like swapping bulbs etc.
    Thanks for the link Sp, I'll check it out... :)
  7. Fod
    26 Aug 2004
    you know, you could just, move the projector to the other end of the room?
  8. airchie
    22 Mar 2005
    Not sure it would work due to the size/shape of the room, hence the over-elaborate option of moving projector mount or scaffolding over a table... :D
