Windows MS Office 2007 automatically places border around large images
Discussion in 'Tech Support' started by Prozone, 11 Aug 2010.
  1. Prozone
    Prozone :)
    7 Jun 2010
    Just wondering if anyone else has the same problem!
    Each time i put a large image (eg 10mb+) on a word document, or powerpoint slide etc, the program places a thin black border around the edges of the image.
    Under borders and shading, there is no evidence of any border.
    No shadows or reflections either...basically it is just a stock image, but for some reason has a thin border around it which i cannot remove!
    Checking this up on google comes up with a million results on how i *can* add a border to images :wallbash:
    Any help will be greatly appreciated!!
  2. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    When you say large images, do you mean in pixel size or just in file size? Say you had a 10MB image that was 100x100, would that get a border? Or would it have to fill a certain amount of space?
    You also might want to have a look at the AutoFormat options.
  3. Prozone
    Prozone :)
    7 Jun 2010
    Large in pixel size and file size...these images are thousands of pixels wide and tall.
    Nothing suspicious in autofomat
  4. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
    Is the border there on print preview?
  5. Phalanx
    28 Apr 2010
    I was just about to type that. It might be a markup done for the sake of design.
  6. Prozone
    Prozone :)
    7 Jun 2010
    Yep, the border appears on print preview and also when im doing a full screen slideshow
