Development MS SQL question
Discussion in 'Software' started by DreamTheEndless, 14 Feb 2007.
  1. DreamTheEndless
    DreamTheEndless Gravity hates Bacon
    27 Jan 2004
    My sql knowledge can be described in the following run-on sentance "I know how to do the things that I need to do, except for when I don't know how to do them - and so I learn how to do them and then I know."
    In that spirit, I was wondering if it's possible to write the following 2 queries:
    10 SQLgeek points to anyone who can give me the (correct) answer. :D
    Select *FunctionNames* from *AllUserDefinedFunctionsOnServer* where *FunctionName* like 'TheLookupValue%'
    (and above for views, tables, stored procs, etc....)
    and
    Select *FunctionDefinition* from *AllUserDefinedFunctionsOnServer* where *FunctionName* ='TheFunctionName'
    (again, I would also want the above for views, tables, stored procs, etc....)
  2. RTT
    RTT #parp
    12 Mar 2001
    perhaps it is just me but i don't understand what you're asking? :confused:
  3. liquid_gen
    liquid_gen What's a Dremel?
    12 Feb 2006
    It's not. I mean i don't know anything about SQL but I do know thats a bad explantion. I'll give ten points to whoever can figure out what he means.
  4. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    So you want to get the name and the code from the udf's on the sql server where they match your lookup value. Makes sense to me but my SQL knowledge is very similar to yours.
  5. DreamTheEndless
    27 Jan 2004
    In plain english -
    (Jamie got it right by the way,)
    First, I want to run a query that will return the names of all the *user defined functions in the database.
    Second, I want a query that will return the code of the *UDF named in the query.
    Make any more sense now?
    * - Or stored procs or views or etc...
  6. DreamTheEndless
    27 Jan 2004
    Something like -
    Code:
    Select name
    from sys.all_objects
    where type_desc = 'SQL_SCALAR_FUNCTION'
    order by name
    or
    Code:
    Select name
    where type_desc = 'VIEW'
    order by name
    That would be query 1 that I wanted above. Any ideas how I could build query 2? (That's the one that actually returns the code.)
  7. DreamTheEndless
    27 Jan 2004
    well - I guess I have to give my points to me -
    (Actually, I'll have to share my points with google, but it took a while.)
    select CMT.text from syscomments CMT
    inner join sysobjects OBJ
    on CMT.id = OBJ.id
    where OBJ.name = 'udf.PhoneNumClean'
