Hardware MSI X38 Diamond preview
Discussion in 'Article Discussion' started by Da Dego, 14 Sep 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. zoom314
    zoom314 Minimodder
    10 Jun 2003
    Looks nice, Hopefully It will have the missing DDR2 Dimm slots installed and working.
  3. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    no floppy connector?
  4. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    No, they still have it :( Look along the board's bottom
  5. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    SECRET FUNCTION?!
  6. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    wow that would be interesting if it ended up with 6 dimm slots, and ya Im curious about this secret function as well...
  7. woodshop
    woodshop UnSeenly
    14 Oct 2003
    please tell me this is just like extra headphone/mic jacks or something and not some dedicated memory/silicon for running skype
  8. Herr_SturmGeist
    Herr_SturmGeist What's a Dremel?
    24 Apr 2005
    I believe its a a modem which you can plug your normal telephone into and then use it on skype, not certain though.
  9. Tim S
    Tim S OG
    8 Nov 2001
  10. wyx087
    wyx087 Multimodder
    15 Aug 2007
    i wonder why MSI is keep using the roller coaster cooler, sure it looks good, but why don't they just do some honest BIOS options and some digital PWM?
    and why have they got the silly skype card? im sure if a customer wants one, they'd buy a proper VoIP phone
  11. Almightyrastus
    Almightyrastus On the jazz.
    21 Mar 2002
    Wouldn't it make more sense to move the pci slot to the bottom of the board and move the 2 yellow slots up? with 2 dual slot gfx cards in you would have no access to a standard pci slot
  12. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Any price estimates?
  13. Guest-16
    Guest-16 Guest
    The BIOS options are there, they just aren't DFI standard. Digital PWM costs more and isn't necessarily better - the v1s gave a greater vDroop but the v2s are meant to be better and you do get finer requirements out of it - but if your engineers and manufacturing lines are used to using the normal stuff, and it works for most people, why change?
    Almighty - Yes, imo it would.
    Skype card - lots of people use Skype so it's a branding thing although I've yet to look into how it works exactly or if it saves you any money.
    No price commitment yet either.
  14. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    the main problem with early digital PWM doesn't seem to have been vdroop so much as they run very hot
  15. Guest-16
    Guest-16 Guest
    Well I've been told by more than one that vDroop was an issue on some boards.
  16. zoom314
    zoom314 Minimodder
    10 Jun 2003
    Yay! No Jmicron crap, I'd rather see Marvel stuff, But If the Si stuff is half as good as the Marvel stuff when overclocking I'll live with It. :D
  17. ComputerKing
    8 Sep 2006
    I think that slot is not missing! There is a Secret on this! also LOL on Skype thing! Any ways SKYPE is blocked programme in UAE :( so this motherboard Skype thing is useless, That copper cooling make it look silly! Aline motherboard, Dam Funny!
    Thanks for the Review.
  18. Tulatin
    16 Oct 2003
    Hey, don't cpmplain about the skype card. It'd add about $3 to the total, and all it really is is a modem that seems to be able to prod ethernet ports or something else of the like while the machine is off. Besides, looked at SkypeOUT rates VS conventional Long Distance lately?
  19. Guest-16
    Guest-16 Guest
    He can't - it's blocked where he lives. :p
Tags: Add Tags
