News MSI's P55 motherboards have a "V-Kit"
Discussion in 'Article Discussion' started by Tim S, 2 Jul 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Floyd
    Floyd Wire Twister
    4 Dec 2008
    Very nice feature but I think it should only be offered on the higher end mobos. I just think it might be a un-needed feature for those buying the cheaper boards.
  3. mjm25
    mjm25 What's a Dremel?
    19 Jan 2009
    is it perhaps cheaper/bring economies of scale to include it on every board, as designs are built around this one key feature?
  4. wyx087
    wyx087 Multimodder
    15 Aug 2007
    surely that's asking a little too much from the average enthusiastic. ever since Core2 CPU's, even the kids are overclocking their CPU and not know how to configure it correctly. with such easy measurements, those kids may stick wires in them and shorting out the motherboard?
    those who are serious can always find information on how to measure online, it's easy, simply use insulating tape to stick a piece of wire onto the point and connect the wire with a multimether.
  5. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I know a fair few people who get the cheaper boards and then still OC the hell out of them. This is a great idea across the range, just wish I had it on my GD-70.
  6. Guest-16
    Guest-16 Guest
    http://forums.bit-tech.net/album.php?albumid=367
    Talk about customer service!!
  7. KayinBlack
    2 Jul 2004
    Epic. Sheer win.
  8. boogerlad
    boogerlad What's a Dremel?
    27 Jun 2009
    Useful for benching.
  9. Krikkit
    21 Jan 2003
    I like the idea, personally. If you don't know what to do with it, you aren't liable to go sticking wires into it. If you did a computer wouldn't last long in your care. :p
    Otherwise it's a useful feature for the more interested benchmarkers, and for those not interested it's not something that will up the price more than a quid or two either. It's not like it's a fancy new OC subsystem.
  10. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Why not sell a device that fits in a 5 1/4 bay which shows the outputs? With its own independent power source (voltmeter batteries last forever) to ensure its accurate. Would be safer i'm sure.
    Though saying that if your even using them you probably don't have your pc in a case heh.
  11. Guest-16
    Guest-16 Guest
    There's a mod project right there!!
  12. KayinBlack
    2 Jul 2004
    I can get my MM in my case while it's still full-without removing any of the four loops of watercooling, in fact.
    Just need a bigger case.
  13. wyx087
    wyx087 Multimodder
    15 Aug 2007
    wait, it's a kit? so you get a free multimeter?
    i need a MM, if they do, i'll buy that!
  14. Guest-16
    Guest-16 Guest
    I honestly dont know, and I doubt it. It's just the brand name.
  15. KriTip
    KriTip What's a Dremel?
    14 Sep 2004
    A DMM is useful, but a scope, particulary a USB scope, can log, record and display noise on the supply signals, rather than just watching a slowly (in comparison) updated DMM LCD.
  16. philheckler
    philheckler Used to be a pc enthusiast
    23 Apr 2009
    I thought the same thing - would be a nice feature......
Tags: Add Tags
