MSTSC question
Discussion in 'Tech Support' started by corvette, 21 Jul 2008.
  1. corvette
    corvette What's a Dremel?
    27 Nov 2001
    Is it possible to access multiple machine VIA 1 ip address
    IE, EXT IP is 10.1.1.54 which has 4 machines on that IP
    i can connect to machine 1
    but i want to connect to machine 3
    is it possible to have access to all 4 and just choose which PC i want to connect to
  2. DougEdey
    5 Jul 2005
    You'll need to forward a port on the router to each computer, then connect to that port externally.
    i.e. port 1234-> PC 1
    Port 1235 -> PC 2
    Port 1236 -> PC 3
    Port 1237 -> PC 4
    connect to 10.1.1.54:<port?>
  3. corvette
    27 Nov 2001
    ok got that but how do i change the port on terminal services
  4. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    you should be able to NAT an outside port to a different inside port
    iirc the rdc port is 3389 by default so you should be able to nat
    <outside_ip>:1234 -> <inside_ip1>:3389
    <outside_ip>:1235 -> <inside_ip2>:3389
    etc
    failing that, http://www.google.co.uk/search?q=change+rdc+port ;)
