Windows Multi monitor software
Discussion in 'Software' started by mm vr, 22 Oct 2009.
  1. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    I bought a second screen a few weeks back, and after trying UltraMon, I've decided that such software is definitely necessary for anyone with multiple screens.
    I'd like to try other such programs aswell before deciding if they are worth buying, though. UltraMon costs $40 and isn't 100% stable (has crashed on me a few times).
    What alternatives are there that I could try?
  2. Nippon109
    Nippon109 What's a Dremel?
    4 Jun 2009
    I've got Display Fusion running. Got recommended by another on this forum. Has been running perfectly, no probs with it and have had it for a few months now.
  3. earlydoors
    earlydoors Minimodder
    12 May 2009
    Looked into the 58 series and Eyefinity?
  4. rivet_joint
    rivet_joint What's a Dremel?
    30 Jul 2007
    Multimon is a decent free software for dual monitors; I use it at work for my dual monitor* setup without any problems. May not have all the bells and whistles of Ultramon, but hey, it's free :D
    http://www.mediachance.com/free/multimon.htm
    * laptop + external LCD.
