Electronics Multiple LEDs to HD activity
Discussion in 'Modding' started by tornaxl, 17 Mar 2006.
  1. tornaxl
    tornaxl What's a Dremel?
    17 Mar 2006
    I am looking to connect multiple LEDs to my HD activity header on my motherboard. I am looking to uses these LEDs (http://www.thinkgeek.com/pcmods/lighting/809e/) but I know I just can't splice them into the motherboard.
    Can someone please let me know if what I want to do is possible. If so how?
    Thanks.
  2. Jokkocze
    Jokkocze What's a Dremel?
    16 Dec 2004
    Well, I'd use a relay. Connect the + (That should go to a led) to the relay, and connect the 12v (or is it 5?) to the relay, and then from the relay to the leds. Should do it. I aint that good at that stuff tho :/
  3. DR_D
    DR_D What's a Dremel?
    8 Nov 2005
    would the relay be able to pulse fastest enough with out destroying the contacts?
    what about an opto-coupler and some transistors?
  4. ARM
    ARM Minimodder
    15 Sep 2004
  5. tornaxl
    17 Mar 2006
    Thanks for the replies. However, I am lost with this optoisolator stuff. If someone can provide a simple diagram of how to connect the HD leads to the optoisolator then to the 12v lead off the LEDs it would help out a ton.
    Thanks
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    A relay won't work, there's only about 10mA available. Opto-isolator is the best way.
    Most optoisolators won't carry the current for several LEDs in parallel so you need to add a current-boost transistor as shown in a few similar threads. :search:
    Get the opto datasheet to sort out the pins.
  7. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    the other reason i would not use a relay is that when the switch they make a clicking noise. which would be very anoying if switching at those speeds.
