Apple Multiple Speakers from MacBook
Discussion in 'Tech Support' started by georgejennings, 29 Jul 2010.
  1. georgejennings
    georgejennings What's a Dremel?
    29 Jul 2010
    I've just bought an ordinary Apple MacBook to replace my old Mesh Desktop and I want to transfer the speakers I have to my Laptop.
    They are made by Creative and on the back of the Subwoofer it says Inspire T7700. I have 4 smaller speakers (2 front, 2 side/back) to create surround sound (I am happy just using the 2 front ones though), all of which, including the Subwoofer, came as a set.
    The smaller speakers go into the Subwoofer and then all the audio it run through three output leads to go into the computer.
    Due to the MacBook only having one slot for headphones I attached a two-way headphone splitter and run the front speakers and Subwoofer through it.
    This seems to work fine at lower volumes but when I try to crank up the volume on different combinations of the Creative volume switch and the computer volume button, the sound seems to disappear from the top speakers and all I hear is sound from the Subwoofer. When I bring the volume back down again, it reverts back to normal, with good sound.
    What can I do/buy to resolve this problem and am I damaging my computer in anyway?
    At the moment my side speakers are obsolete, is there anyway I can use them?
    I am very particular about the sound quality so I would like to maintain as higher quality as possible.
    Thanks for any help or suggestions,
    George.
  2. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
  3. georgejennings
    29 Jul 2010
    Thanks, that would be perfect, but it is a bit pricey for a mere student. :)
    Is there anything for cheaper?
    I was hoping to pay around £20-30.
    Thanks for the help!
    George.
  4. saspro
    saspro IT monkey
    23 Apr 2009
  5. georgejennings
    29 Jul 2010
  6. riekmaharg2
    22 Feb 2009
