Scratch Build – In Progress my 3e mod >>>>FINISHED<<<<
Discussion in 'Project Logs' started by rambo, 15 Mar 2007.
  1. rambo
    rambo What's a Dremel?
    14 Mar 2007
    hey this is a project log of my thirt mod and i ame still looking for a name but he modding is cooler than sitting and thinking :p
    if you now a cool name tell me, thanks
    rambo
  2. Jipa
    5 Feb 2004
    Lol @ pinkbike.com-host! This isn't really a project log so the forum is kinda wrong.. Atleast so far.
  3. rambo
    14 Mar 2007
    yeh i know but ime working on my 3e project and i ame colecting pictures and stuf so i can post that.
  4. Jipa
    5 Feb 2004
    Ok cool I just misunderstood.
  5. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    You've got it hanging from the ceiling :eyebrow: :confused:
    :D :p
    Welcome to the forums :thumb:
  6. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    lol didn't notice that. That's tight
  7. wbdog206
    wbdog206 not me
    15 Jan 2007
    thats sweet iv been thinking of putting mt main rig under my desk like that..
    nice work there. cant wait to see more.
  8. rambo
    14 Mar 2007
    that is under my desk :rock: you can see it on the other pictures:)
  9. rambo
    14 Mar 2007
    finaly some pictures and my idee of my 3e project. ime building my case form 2 matirials: mdf and alu dymond plate. i have already build my mdf case (inner case) and i have the outer case to, i had some guy i know weld it for me because i cant weld alu :waah: .
    ime going to put the mdf case inside the alu case because mdf is easy to mound my stuf to. and wen its don the outer case is smoother because i dont have to screw every thing on the alu plate.
    also ime going to put 2 more 120 mm fans in my case one on the top and one on the bottom i dont know wy (beacuse its cool) with 2 more fan controlers because i like it sillent.
    the feet of my case are going to be alu round bar 50mm in diameter were ime going to mill a quarter peas out off, with 25mm high 50mm diameter perspex bottom feet (with green leds in it) screwd onto the alu bar.
    ime going to use glass or perspers windows on the left side and the left side is going to open like a 2doors window with 1 side hooks underneeth the other side. look at the sidefew foto the middel line is going to be the line were ime going to cut the dymon plate in half and the striped line next to the middel line is going to be the mdf saw line.
    here are the foto's, bad picture's but thees are drawings i made from the front side and the left side you see the 120 mm fan the 5 knobs from the fancontrolers and the alu/perspex feet the glass windows and the window like doors.
    wooden case from mdf plate to mdf case:
    form dymond plate to dymond plate case:
    two cases inside each other:
    perspex bar to perspex feet 25mm high 8mm M20X1 treath and a curfed peas ad the bottom to spread the light.(i hope):
    see you next time, rambo
  10. wbdog206
    wbdog206 not me
    15 Jan 2007
    looks good nice work
  11. Qbank
    Qbank What's a Dremel?
    19 Jun 2002
    looking good
  12. Evenge
    Evenge Minimodder
    16 Sep 2006
    Looks nice! :thumb:
  13. widmod
    widmod Minimodder
    9 Oct 2006
    great work :thumb:
    why do you need the mdf? isn't the diamond plate enough for stability?
  14. ry@n
    ry@n Minimodder
    31 Aug 2005
    Looking good!
    Pinkbike delete all non-bike photos btw...
  15. rambo
    14 Mar 2007
    thanks for the replays. pinkbike dos not remove the pictures if you see its for forum use :D . and i use the mdf for mount every thing onto so the outside of the case is smoother.
    ,rambo
  16. rambo
    14 Mar 2007
    jojo finaly an update i had almoost now time to work on this project so here are some foto's from my case: i sawd some holes in it and i made a mold for my 120 mm fans. also i made an motherboard bracket from 2 cases i hade becaus i liked the rear side off 1 and the motherboard hanger from the other.
    the fan mold with a fan mounted on.
    the metal case with holes in it. (front side and rear side)
    the wooden case with holes in it.
    the wooden case inside the metal case you can see that the holes inside the wooden case are bigger then thee are in the metal case. i did this because the fans are than 12 to 18mm deeper than normal wat meens more space inside the case.
    this is my motherboard bracked made from of 2 old ones.
    and finaly all the things togheter.
    work in progress (turning and milling the alu case feet pictures soon)
  17. rambo
    14 Mar 2007
    just a small update from my cd,hdd hanger and a no cd plate that i can plase in if i only juse 1 cd drive. the cd,hdd hanger was from my old sweex case and i drillt out all the nails and replaset the bottem and the top for 8mm mdf because the bottom is not tuching the bottom of my case. the top has to be 8mm mdf because its a spacer to get it in the richt position.
    the hanger:
    the two hamer in bolts (or somthing) to mount the hanger:
    the hanger in plase:
    the hanger and every thing els so far:
    the no cd plate:
    the front without the no cd plate:
    the front with the no cd plate:
    work in progress
    see ya, rambo
  18. rambo
    14 Mar 2007
    jojo just an update off the project so far almoost done now.
    1 case feet:
    all the case feet (4) :
    my case from the top with case feet:
    my case form the front with the case feet:
    almoost compleet from the front:
    almoost compleet from the side closed:
    and almoost compleet from the side open:
    see you next time.
  19. rambo
    14 Mar 2007
    hey dudes what do you think off it so far? im ame almoost finished and im ame painting it black now, waiting for new hardware to put in it as well. i hope it comes in soon :lol:.
    thanks, rambo
  20. Teyber
    Teyber ******
    18 Mar 2007
    wow thats awsome!
    can i recomend that you paint the MDF(wood) before you finish though? black would look nice
